587,008 active members*
3,670 visitors online*
    Feb 2009
    16
    Linistepper troubleshooting
    Hi all,
    I've constructed a linistepper board (posix style), but can't get the motor running. I'm providing the input with a 555 tester circuit.
    I get ~10.3V between GND and all motor outputs, and maybe 0.5 in between the common and the coils. I've tested the 555 circuit and it provides the signal ok. I've replaced the TIP122s already, still the same. Any ideas?
    Thanks ahead,
    Peter
    May 2005
    1397
    Start in the middle, check for valid signals, move in the direction of the invalid signals.
    Feb 2009
    16
    Thanks James, I've ended up trashing the circuit and building a new one. This one works fine.
    May 2005
    1397
    Glad you got something going... I guess sometimes chucking it all and starting over is best!
  1. Linistepper new board
    By salvado in forum Open Source Controller Boards
    Last Post: 05-20-2016, 12:33 AM
  2. I think i am going the Linistepper route
    By phantomcow2 in forum PIC Programing / Design
    Last Post: 03-14-2009, 06:19 PM
  3. Linistepper update
    By posix in forum Open Source Controller Boards
    Last Post: 10-14-2008, 07:20 PM
  4. 'Lil Linistepper Lathe
    By epineh in forum Mini Lathe
    Last Post: 02-24-2008, 03:03 PM
  5. Linistepper
    By tante in forum Open Source Controller Boards
    Last Post: 12-19-2005, 04:24 PM
