586,547 active members*
3,264 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > Model V8 engine plans required
Page 4 of 27 2345614
Results 61 to 80 of 525
  1. #61
    Oct 2006
    708
    Thanks Steve. Keep it coming!
  2. #62
    Dec 2006
    603
  3. #63
    Aug 2009
    899
    Wow that is awesome. how long did it take to mill that block down and what kind of mill did you machine it on?
  4. #64
    Oct 2006
    708
    Quote Originally Posted by eartaker View Post
    Already answered. See:
    http://www.cnczone.com/forums/showpo...4&postcount=35
    http://www.cnczone.com/forums/showpo...7&postcount=40
    http://www.cnczone.com/forums/showpo...8&postcount=43
  5. #65
    Dec 2006
    603
    Hello everybody!
    Finally managed some progress this week. I spent the weekend at the Detroit Maker Faire so today I almost finished the intake manifold. First thing i did was drill the mounting holes thru and then spotted the passages with an endmill about an eigth down.
    Finished drilling the water passage and the fuel passages on both sides. The vise is tipped on a 5 degree angle.
    Wasen't sure about this one but i used the new angle blocks to tip the part at 68 degrees. I was a little worried but it worked perfectly.
    Then I drilled to intersect the fuel passages both forward and backward.
    Bolted it on the block to be sure it fits. The only thing left is to drill the distributor hole and finish threading a few holes and it should be a keeper.
  6. #66
    Dec 2006
    603
    The valve corvers took forever.
  7. #67
    Oct 2006
    708
    Nice looking twins you have there, Steve!
    What are you going to do with them, if that isn't a rude question?
  8. #68
    Dec 2006
    603
    Quote Originally Posted by dynosor View Post
    They will be displayed at shows. I might make the plans available. If not I might ask Rhemus if he would like to do a piece and the plans in MEB magazine. One with just a carb and one with a blower if i can pull it off.
  9. #69
    Dec 2006
    603
    Managed some garage time today. Worked on the bellhousing.
    I still need to drill the hole pattern to mount the piece but that should be a quick deal!
  10. #70
    Dec 2006
    603
    Had the chance to make some cylinder liners today.
  11. #71
    Oct 2006
    708
    Quote Originally Posted by stevehuckss396 View Post
    Niftey!
    Steel or cast iron? Reamed or cut with a boring bar? Honed? CNC? Too many questions?
  12. #72
    Dec 2006
    603
    Niftey!
    Steel
    Boring bar
    Not yet honed
    Not CNC
    Looking for a lathe. Then the lathe i have now will be CNC!
  13. #73
    Dec 2006
    603
    One done, one to go
    Tomorrow the other block will get finished.
  14. #74
    Dec 2006
    603
    Victory!
    Both blocks are completed! Not sure where i'm going to go from here. I have to work 12 hour days for the next week so I will have lot's of time to figure it out!!!!!
  15. #75
    Aug 2010
    I am IMPRESSED! Not only with your great work and design but the philosophy of keeping it as simple as possible for...well not beginners but I suspect this project (with your plans and some forum assistance) should be doable by anybody who is ready for multi cylinder projects. I think leaving lubrication of the top end up to the operator is a great way to keep things reasonable. PLEASE make the plans (AND CAD/CAM/G-Code) available when you are done!
    Looking at the size I believe I should be able to do all the milling on my Taig 4 axis CNC. Do you agree? How is it your big mill has only five inches of Z? Tool holder clearance?
    I am NOT ready for such a project but I WILL purchase the plans as soon as they become available.
    Will you also release the supercharger plans "if you can manage it"?
    Gary B in BC starting (still a lot of frustration) to enjoy CNC
  16. #76
    Apr 2010
    486
    Quote Originally Posted by fly_boy_bc View Post
    My Bridgeport has only 5" of Z travel. Lots of table travel, (10 x 18) but not much Z.
    Tom
  17. #77
    Dec 2006
    603
    I'm not sure but the hardest part is boring the crank and cam tunnels. The block is 4.936 so if you could do a bore that deep on your equipment, you can do the rest. I have seen folks do the boring on the lathe but it is much more work.
    5 inches is the standard travel for a Bridgeport milling machine.
    Thanks !!
  18. #78
    Aug 2010
    Thanks !!
    Wow colour the noob surprized! My little taig is 5.5x12x6! With a max z hight of 9".
    Should be no problem at all 
  19. #79
    Aug 2010
    All I have to do is take lighter cuts.
    Thanks !!
  20. #80
    Feb 2007
    5
    could you imagine to give away the plans on installments? :idea:
    Then i could start with the block and build the other parts as they are ready.
    I will have to do a metric version of the plans since i live in germany.
    Adrian
  1. Engine Plans
    By nzer in forum MetalWork Discussion
    Last Post: 08-03-2012, 05:14 PM
  2. I.C. engine plans
    By cumminsman in forum I.C. Engines
    Last Post: 04-10-2012, 11:43 PM
  3. Does anyone have any good jet engine plans?
    By flyguy1254 in forum Hobby Discussion
    Last Post: 04-16-2010, 10:28 AM
  4. Jet Engine plans
    By godspeed in forum Hobby Discussion
    Last Post: 05-18-2007, 11:34 AM
