i am trying to establish a RS232 connection between a pc and okuma LB300 with control U100L. Always i get an error 5235 device name error 2, which i can't solve it.
Any ideas?
Any ideas?
Please correct me if wrong, but
does this machine come with a network card and set-up thru the "Macman" application and use an ethernet cable ?
If yes, it would be better than using a RS232 with a PC terminal, all comms can be done at the machine with no contact with the PC
does pushing the "!" button near F1 key give any other info on that alarm #5235 ?
My machine hasn't a network card to connect. Sorry!
i tried to write after "PIP"-"READ"- R CN0:a.min but i get the same error.
I don't know wish DNC program you use but, on our machines, we have:
$program name.MIN% (at the beginning)
M02
% (at the end)
DNC SETTING:
BAUD RATE: 4800
PARITY: EVEN
DATA BITS: 7
STOP BITS: 2
TRY THIS AND GIVE NEWS !!!
this error indicates wrong device name clearly. The best for beginning is to use default device, set by parameters, not typing device name into command. Pay attention - parameters describes separate serial communication ports for parameters, for reading and for punching part program. By the way, You can use "punch", it would be normal for this control.
Hi have the same problem, but I the punch work, but the read don't work ! I need help to.
