586,318 active members*
3,746 visitors online*
Results 1 to 10 of 10
    Jan 2008
    47
    broken foot pedal
    Broke the connection for my chuck clamp/unclamp foot pedal.. how to I clamp unclamp w/o? I can unclamp in MDI with M11 however when I then try to chuck with M11 it errors that the chuck is unclamped... Need to resume production asap!
    Nov 2005
    196
    Interesting problem. I wonder if you can trick the machine by switching to ID chucking then program in to open the jaws followed by m0 so you'll have time to close the door. You'll also have to override the door safety switch.
    Jan 2008
    47
    hmmm... ill try... how do you switch to id chucking?
    Nov 2007
    188
    open / close chuck
    It is possible to do this if you change the parameter setting CHUCK OPEN CS to 1 it will allow you to open the chuck in MDI when it is closed all though I would only use the as a last resort because the spindel will also run with out the chuck clamped and this could be bad!!! I would not let an operator do this but to finish out a job or part I may do it my self I not sure if it will affect anything else so be very careful.
    Jan 2008
    47
    found the id chuck setting.. thanks! i will try to change the parameter as well and see how that goes! thanks for your help!
    Nov 2005
    196
    Seems like it shouldn't be too hard to repair the broken connection.
    We didn't use ID chucking very often but I think it's under Settings.
    Jan 2008
    47
    Quote Originally Posted by Technical Ted View Post
    well, no, it shouldnt be that hard to fix it.... it did break the plastic tho. I just wanted to cut open the back of the connection box, extend the leads, and plug those into the pedal... But boss says we should just order a new one.. haha whatever
    CHUCKER:
    How do I unlock the abillity to change params? says FUNCTION LOCKED when I try to adjust it....
    Nov 2005
    196
    I haven't run the Haas in a while that's why I'm not 100% certain but I think you have to change a Setting before you can change the Parameters.
    Nov 2007
    188
    open / close chuck
    go to the setting page and turn on setting 7 this will unlock it for you it may say servo is on if so just push estop then try to change it again
    Jan 2008
    47
    Quote Originally Posted by chucker View Post
    Now I'm ready to throw some parts across town! :banana:
    Thank you all for your help!
  1. Miller TIG pedal--> 14 pin to 6 pin
    By stag53 in forum Welding Brazing Soldering Sealing
    Last Post: 02-25-2009, 03:11 AM
  2. Any way to add foot-pedal to old Tig Welder?
    By Stuff-Builder in forum Welding Brazing Soldering Sealing
    Last Post: 12-18-2007, 08:21 PM
  3. Looking to get my foot in the door!
    By Tim Wiltse in forum Employment Opportunity
    Last Post: 09-17-2007, 01:31 PM
  4. wasino foot pedal trouble
    By AFX in forum Fanuc
    Last Post: 07-04-2007, 03:10 AM
  5. I need to cut a 20 foot sheet on a 10 foot table. How? Indexing???
    By Apples in forum Waterjet General Topics
    Last Post: 11-11-2005, 02:27 PM
