586,497 active members*
3,116 visitors online*
Results 1 to 13 of 13
    Dec 2008
    9
    memory card of FANUC 15MB
    i tried to save the system data of FANUC 15MB with a 64M cf_card.but the screen displayed: memory card mounted error.then i use the controller to format the card.the screen displayed:executing.the processing of format lasted about for four hours.it seems like endless and then i have to turn off the controller to unplug the cf_card.i am wondering is it necessary to change the system settings. what kind of the card the 15M system can support? is 64M cf_card too big?maybe i need a 8M cf_card?
    does anyone can tell me the reason?
    thanks in advance for your help.
    Jan 2007
    93
    A special Flash memory card will work on Fanuc 15MB system.
    That u will hv to purchase from Fanuc it self.
    It is older type card uses 15 vdc .
    Dec 2008
    9
    hello rajesh_1355:
    thank you for your promptly reply.
    now i know the reason.
    Dec 2006
    5
    Hallo, you need a SRAM card for 15 MB not other model !
    Bye Andrea
    Dec 2007
    12
    15 mb fanuc
    pl.use SRAM CARD OF 1 OR 2MB memory.You may purchase it from fanuc or Ebay.
    Apr 2009
    1379
    You should use a PCMIA SRAM card. DO NOT buy from Fanuc. We use a 4Mbyte size so that we don't have to swap cards during installations. We manufacture
    memory upgrades for this control as well as others.
    go to TULIPMEMORY.COM
    Feb 2009
    6028
    You can buy fujitsu SRAM card on eBay. 2 mb is all you need. Large ones won't read.
    Apr 2009
    1379
    "You can buy fujitsu SRAM card on eBay." we have no problems with any brand, including Pretec, Seiko Epson, Mitsubishi. Pay about US$ 150 for 4 Mb.
    " 2 mb is all you need." 512k is all you NEED (maximum file size); larger is more convenient.
    " Large ones won't read." untrue- we have been using 4 Mb for 15 years.
    Feb 2011
    100
    Quote Originally Posted by memoryman View Post
    Do you make one for a 21i-MA?
    Apr 2009
    1379
    are you referring to the pcmcia card? These can be used on all Fanuc controls that have slot for them, including the 21ia..
    Feb 2011
    100
    Yes. The PCMCIA card. I cant seem to get any to work. When i try to format them it says that the card is protected. If I try to write something gives me a "Memory card error 0007".
    Mar 2008
    169
    You can't use ATA pcmcia card in a 15MB, they only work on Fanuc i Series. Like Memoryman said, Buy a fujitsu Sram Card.
    Carlos
    Apr 2009
    1379
    all pcmcia memory cards have a write protect switch; make sure it is OFF.
  1. GE Fanuc 18i-MB: Memory Card Error 0030
    By andyinwi in forum Fanuc
    Last Post: 05-16-2010, 12:12 PM
  2. Where/How to buy Fanuc Memory Card
    By marcwdci in forum Fanuc
    Last Post: 07-19-2008, 02:57 PM
  3. Fanuc 16i memory card
    By jamie pinols in forum Fanuc
    Last Post: 02-26-2007, 01:50 AM
  4. Fanuc 6M-b max memory card A87L-0001-?
    By Drew in forum DNC Problems and Solutions
    Last Post: 03-26-2005, 02:08 AM
