Hello - I have a Tree 2UVR miling machine and I am trying to locate a M-1617 timing belt. This belt goes underneath the head and drives the spindle down feed. I would like to know who many teeth are on this belt. Thanks - mpoole
Mpoople,
Just go to your friendly automotive supply store and get a v belt that will
fit. No cog teeth needed.
regards,
Jim
if you are refering to the "timing belt" located in the bottom of the head housing it has 56 teeth on it the part no. is m-1616 it is located just above the belt marked part no. m-1617 in the parts book. 3s has these in stock and can fix you up.
Thanks for your response. I have the M-1616 belt. The one I need has M-1617 stamped on it. The name in the parts manual is 9246 x 1/2" R3D1 Gilmer timing belt. It should have approx 50 teeth. I have tried 3S several times, the last time the number has been disconnected. Do you know of any other source?
