586,446 active members*
3,395 visitors online*
Thread: Coolant Pan
    251
    Coolant Pan
    Finished my flood coolant pan yesterday and have it all installed now. Will probably order the Enco coolant tank and pump unless something better pops up. I have a big steel job coming in a few weeks and wanted to be ready for it. The pan is 14 gauge sheet metal, I had a local fabrication shop shear and brake the major pieces then I brought it all home and finished cutting and welding it up. I basically copied the diminsions of the basic stand pan except mine is about 1 inch deeper, I wanted steeper angles on the side to ensure rapid coolant return.
    BlueFin CNC LLC
    Southern Oregon
    Jan 2009
    6
    Red face QUESTION???
    I WILL APOLOGIZE AHEAD OF TIME FOR THIS IS TO ASK YOU A QUESTION ALTHOUGH YOUR BUILD LOOKS GREAT. I HAVE A CINCINNATI MILCRON SABRE THE TOOL CHANGER WENT DOWN AND WAS WONDERING IF WE COULD CONTINUE TO RUN CHANGING TOOLS MANUALLY WITH A PAUSE INSERTED IN THE CODE AT TOOL CHANGE. ANY INFO YOU MAY HAVE WOULD BE HELPFUL AND WOULD THE INTER-LOCK DOOR CREATE A PROBLEM?
    251
    Uh, I think you might have posted in the wrong forum, this is a Tormach mill area.
    BlueFin CNC LLC
    Southern Oregon
    Jan 2009
    6
    my bad
    May 2005
    2502
    Blue Fin, that's a great looking pan!
    May I ask ballpark what the fab shop charged? I'm curious before I go charging down to my local fab with a similar request.
    Will you be adding walls?
    Cheers,
    BW
    251
    Quote Originally Posted by BobWarfield View Post
    BW
    The fab shop bill for materials and labor was $137.00 plus $12.00 for two cans of spray paint. It took me two evenings after work to trim, assemble, weld and paint the pan. Then about 2 hours this weekend to rent an engine hoist for $10.00 to slip the pan underneath it. Oh, I machined four 3/4" inch blocks with a 1/2" hole in each one to raise the machine up off the pan, I had some scrap laying around for that. Because I didn't plan ahead back in September, the four mounting bolts that I bought originally were a 1/2" too short now. So I had to buy $8.00 in new bolts ( I got some slightly used 5" 1/2" X 7/16" bolts I'll make someone a heck of a deal on! )
    BlueFin CNC LLC
    Southern Oregon
  1. Coolant...Which and why?
    By ajl6549 in forum MetalWork Discussion
    Last Post: 12-08-2008, 03:02 PM
  2. Coolant and way oil
    By Cairns in forum Tormach Personal CNC Mill
    Last Post: 08-13-2008, 02:24 PM
  3. Coolant??
    By WingNutz in forum Mastercam
    Last Post: 12-06-2007, 05:55 PM
  4. What to do about coolant?
    By petriej in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2007, 01:11 AM
  5. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
