586,804 active members*
7,681 visitors online*
IndustryArena Forum > CNC Electronics > Xylotex > Pop noise in 3 Axis Xylotex board
    Aug 2007
    9
    Hi everybody,
    This is my first post. I am in the process of making a CNC plasma cutter. My basic setup is a a CNC4PC breakout board, 3 Axis motor driver and 3 stepper motors. I use EMC2 for the controller. I had all of the motors working great for quite awhile. I then added connectors to my cables for the motors and moved the machine to a new location.
    When I turned the system back on, after a few minutes I heard pop noise. There was no smoke anywhere. I then noticed that the driver board was not working. I unhooked everything except the 24VDC and still nothing. When I turn the system on, the red LED turns on for a second and then off.
    There seems to be a short across the 24VDC.
    Anybody have any idea how I would go about fixing this. I sent an email to Xylotex, but wanted to see if anyone here had any experience. I also am concerned because I have no idea what is wrong. I checked the motor wires and they all seem to be fine.
    Jan 2009
    265
    Sounds like magic smoke, check motor wiring with an ohm meter.
    Aug 2007
    9
    It looks like it is a bad motor. I checked the resistance on all the motors and they were all at 2.4 except one was at 1.2.
    I connected the power to the driver board and noticed that out of the 3 axises only 1 was getting hot. I removed that chip and now the board works.
    Looks like I had a bad motor.
    This may be a dumb question, but what is magic smoke?
    Jan 2009
    265
    B7, this magic smoke is what numbnuts like myself use to describe an electronic short out.
    Example; hooking up 3 phase power to 5v capacator or such.
    Xylotex are pretty good on price for repairs i have heard.
    Would be nice if they mounted the chip in a socket and fused each output somehow, apparently fusing is not possible though.
  1. Xylotex board help
    By CROSSHATCH in forum Benchtop Machines
    Last Post: 07-09-2008, 04:49 PM
  2. xylotex board on its way
    By gun_mike in forum Xylotex
    Last Post: 07-18-2007, 11:47 AM
  3. Replies: 5
    Last Post: 04-11-2007, 07:47 AM
  4. Replies: 14
    Last Post: 03-07-2007, 12:39 PM
  5. Will a Xylotex board be any different?
    By phantomcow2 in forum Xylotex
    Last Post: 10-23-2005, 02:50 PM
