I'm sure there are other methods, but a couple I use is:
(1) I keep a spare (standard if you wish to call it that) of certain smaller parts & lay a fresh cut piece over the "standard" & visually check for error.
(2) Every so often I'll cross measure a sheet usually 5' X 10' to be sure it's square. Place that on my table & carefully measure to make sure it is parallel with the table. Draw in the exact dimentions of the sheet in CAD, convert to .dxf, generate code, send to torch & let it trace the outline of the sheet in real time watching to see it traces the outside edge of the sheet exactly.
I have never had a problem of my torch cutting to size unless I goofed on the drawing. I mainly use the full sheet trace method to be sure my home limit switches are still doing their job in squaring the gantry to the rails. & to be sure the table hasn't been knocked out of square by a forklift.
Neil
If it works.....Don't fix it!
