586,281 active members*
3,778 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Interesting "Gross Position ERROR A" with no limit detection
    Oct 2008
    32
    Hello Everyone,
    I have a more interesting "GROSS POSITIONING ERROR A" Problem. I switched ON my machine after more than one year of use .When i was referencing the machine axis it referenced the Z axis normally and when i tried to reference the Y axis it came up with the "GROSS POSITIONING ERROR A"..................................
    Now the interesting thing is that after turning ON and OFF the machine many times the " Y axis Reference " line on the CRT became highlighted and the Y axis motor started to rotate in opposite direction i.e. the table started to move away from Y reference and without detecting limits.
    Is there any one who faced such a problem ever ???????? for TNC 151
    A.A
    Nov 2006
    925
    Check the home limi switch and wiring on the Y axis.It sounds like it thinks it`s already on the cam when you try to reference.It then tries to move of the cam,does not see the input changing and keeps going until it faults.
  1. "Gol-Matic" mills; interesting setup
    By Swede in forum Uncategorised MetalWorking Machines
    Last Post: 09-24-2009, 01:35 AM
  2. Gross Position Error
    By Mike Conboy in forum Bridgeport / Hardinge Mills
    Last Post: 06-15-2009, 09:38 AM
  3. "FUN JOB" CNC Machinist Position in Plano, TX(Dallas)
    By TRAXXAS in forum Employment Opportunity
    Last Post: 12-31-2008, 10:15 PM
  4. Bridgeport VMC308 - Gross Position Error
    By mcwmah in forum Community Club House
    Last Post: 11-09-2007, 10:34 PM
  5. EZTRAK Y axis loosing position, "slipping"
    By melamark in forum Bridgeport / Hardinge Mills
    Last Post: 12-18-2005, 08:23 PM
