586,485 active members*
2,783 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18i-T "1114 main spindle orient fault"
    Jan 2009
    6
    Having trouble with a "1114 main spindle orient fault" on a hardinge TT-65. It has a fanuc 18i-T controller. Any help would be much appreciated.
    Jun 2007
    44
    Quote Originally Posted by Jeff_Mezzo View Post
    We have Mori Seiki mill with 18i and had problem with spindle orientation for tool change parameter 4077 worked for us. Try changing parameter 4077 or check out this
    http://www.machinetoolhelp.com/Repai...ientation.html
    Mar 2008
    95
    don't change param 4077 it is for turret orientation on your tt-65.
    Jan 2009
    6
    Thanks for the input guys, ended up being a bad drive, main spindle drive to be exact. Thanks again for the input.
  1. "low end" HF Spindle or "high end" router for about $1000?
    By biomed_eng in forum DIY CNC Router Table Machines
    Last Post: 01-06-2012, 07:15 AM
  2. Bridgeport Int. 316 "Spindle Orient Alarm"
    By mbpp in forum Bridgeport / Hardinge Mills
    Last Post: 08-29-2008, 04:39 AM
  3. "SPINDLE DRIVE FAULT"
    By offroadxx in forum Bridgeport / Hardinge Mills
    Last Post: 01-16-2008, 03:38 AM
  4. V2XT error message "DRIVE FAULT detected (0,z,y,x) check log"
    By rfdoyle in forum Bridgeport / Hardinge Mills
    Last Post: 10-08-2007, 09:35 PM
