587,507 active members*
2,621 visitors online*
    Dec 2008
    PMDC Motor Control, MC-60M
    I have a small Knee mill (Clausing 8520) that I plan to power with a PMDC treadmill motor rated 2.65 h.p. @ 130VDC. Below are a few of my questions.
    Any ideas on how to modify a MC-60M control board to reverse direction? Or, is it best to just use a DPDT switch/contactor between the controller and the motor? Does the choke have to be on the negative(A-) side of the motor circuit?
    Anyone know how to disable the soft start/stop feature?
    Finally, what happens when you clip RPS3?
    PK
    24220
    Just looking over the spec's on that board, If you have not already purchased one, I would think the better route to go would be a KB or Baldor style, they can be had off ebay very cheap, even new, they are around the same cost as these units.
    If it is a two quadrant drive, which these appear to be, the KB/Baldor have an interlock which prevents going immediately from forward to reverse, a four quadrant drive will have auto reverse and dynamic braking, a 2 quadrant, you have to reverse the motor leads and have some way of preventing immediate reversal.
    Al.
  1. dc motor control?
    By cueshark in forum CNC Machine Related Electronics
    Last Post: 02-22-2008, 10:51 PM
  2. dc motor control
    By snowshovelbmx in forum CNC Machine Related Electronics
    Last Post: 10-17-2006, 10:32 PM
  3. Motor control
    By mihavoncina in forum CNC Machine Related Electronics
    Last Post: 04-29-2006, 01:16 AM
  4. Looking for a source for PMDC servo motors
    By bgolash in forum Servo Motors / Drives
    Last Post: 01-31-2006, 10:26 PM
  5. DC Motor Control
    By foamcutter in forum CNC Machine Related Electronics
    Last Post: 03-10-2004, 09:32 PM
