586,905 active members*
3,167 visitors online*
IndustryArena Forum > MetalWorking > Welding Brazing Soldering Sealing > Miller TIG pedal--> 14 pin to 6 pin
    Nov 2007
    59
    Hi all,
    Long time reader, occasional poster.
    Has anyone here adapted a Miller 14 pin pedal to a 6 pin machine? I'm switching out my Syncrowave to a Maxstar... space limitations... I'd like to avoid having to buy a $225 pedal to go with it. I would assume it's mostly a matter of figuring out which wires are what and splicing into a new DIN connector?
    Thanks in advance!
    Adam S
    Nov 2007
    59
    Found the manual
    Well, looks like I answered my own question. Miller has a wiring diagram with both the 6 and 14 pin diagram on the same page...
    Just need to order a connector and I'm in business.
    Nov 2007
    59
    Progress...
    Thought I'd post any progress I make, in case someone else wants to pursue this...
    Found this company via Ebay and followed the pedal to their website where they sell the connectors: http://www.ssccontrols.com/index.htm
    I'm thinking about making an adapter with a male 14-pin plug on one end and 6-pin female plug on the other... cleaner and more flexible than lopping the 14-pin off (and if I ever switch back to a welder with 14-pin remote, it's easy to switch back).
    Will update further as things move forward...
    Adam S
    Feb 2007
    1084
    Sorry nobody could help you with that. But please post up, it's good for future reference!
    And SSC Controls is local for me, they make nice stuff! I have one of thier foot pedals, top notch quality.
    MC
    Nov 2007
    59
    Wrap-up
    Just thought I'd finish this post in case anyone is looking to do this...
    I bought a 6-pin connector from SSC controls. It had a 2' pigtail on it... $30.
    I gave up on making an adapter cable as it would have cost about $75 for the connectors. Anyhow, I cut the 14-pin from the pedal and wired it all up referencing SSC's documentation and Miller's to get the wires connected right.
    First arc: hit the pedal and got full current at the top of the stroke, min at the bottom. Ooops. Easy fix:
    Pins 3-4 should read 1,000 ohm (plus or minus 10%) with the pedal in the upright position. This is the red and green wires for the Miller model.
    Pins 3 and 4 for the SSC setup are blue and brown. However, the main thing is that the Miller have 1000 ohms between pins 3 and 4 with the pedal up. As the pedal is pressed, this should go to zero.
    Second arc: success! The little Maxstar welds pretty good... not as good as my old Syncro, but at a 1/8th the weight and size, it's pretty cool (and I can run it on 110 or 220!).
  1. Miller 180 syc wave tig
    By larry53 in forum Welding Brazing Soldering Sealing
    Last Post: 02-08-2008, 04:02 AM
  2. Any way to add foot-pedal to old Tig Welder?
    By Stuff-Builder in forum Welding Brazing Soldering Sealing
    Last Post: 12-18-2007, 08:21 PM
  3. wasino foot pedal trouble
    By AFX in forum Fanuc
    Last Post: 07-04-2007, 03:10 AM
  4. Miller tig
    By kenlambert in forum Welding Brazing Soldering Sealing
    Last Post: 03-01-2007, 12:04 AM
  5. Miller Tig
    Last Post: 04-24-2006, 09:49 PM
