586,410 active members*
3,429 visitors online*
    Sep 2003
    1470
    Question Mach3 View Screen too BIG
    I started up Mach3 Mill this morning and the main View screen is bigger than my monitor will display, can only see about 70% of the screen that is normally displayed, the rest is larger than the monitor screen?
    Opened Mach3 Plasma and it was the normal size. It filled the monitor screen perfectly.
    How can I set it back so that the Mach3 screen only fills my monitor screen.
    Hager
    Sep 2003
    1470
    I found the answer:
    Go to Config menu then General Config and check the Auto Screen Enlarge option, it will shring your screen to fit your monitor.
  1. Mach3 screen set
    By PEU in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-28-2014, 11:00 AM
  2. New Mill Screen for Mach3
    By chris59 in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-19-2011, 05:18 AM
  3. New Mach3 Router Screen
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 07-08-2008, 03:06 PM
  4. 6 axis screen of mach3
    By ayhan in forum Mach Software (ArtSoft software)
    Last Post: 02-21-2008, 11:24 AM
  5. Personalizar el screen del Mach3
    By Creisen in forum Spanish
    Last Post: 07-19-2007, 01:30 AM
