586,535 active members*
2,860 visitors online*
Thread: New Wizard
Page 1 of 4 123
Results 1 to 20 of 77
    Oct 2006
    51
    New Wizard
    After some frustration using a few of the included wizards in Mach I decided to try my hand at making a few of my own. This wizard will do 5 different circular routines from one page. I've made every attempt to make it as bug free as possible. One of the problems I ran into with a few of the included Wizards were the ability to "break" the code with values that were out of range. This seemed to happen often due to the input dro's being scattered around the screen. I always seemed to miss something. I tried to make this one so that it would flow from top to bottom without giving you a headache searching around for the right DRO. I hope I don't come across as too critical because the folks who make these are generally volunteers and I learned a lot by studying their scripts. I am not a programmer so this was somewhat of a learning experience for me but very enjoyable. Most of the code I just wrote myself but a bit of it was copied from an existing script and modified to work within my script.
    I hope it can be of use to someone else besides my me.
    In case you have never installed a Wizard just follow these steps.
    *Unzip the files
    *Put the M700.m1s file into the Mach3Mill folder under the Mach Macros directory
    *Put the whole folder called "Andys Circle Routines" in the Addons folder
    That's all...
    The new wizard should be on the list when you call up the wizards in Mach.
    If there is enough interest I may start on some rectangular pocket wizards.
    Andy
    BTW.... A short explanation of some of the buttons
    There is a 3 AXIS/2 AXIS button to change the code output for people like myself who have simple 2 axis machines
    The other one is somewhat self explanatory ...it is the option to climb or conventional cut.
    The other gives you a choice of Inch or Metric output.
    Not all of the input values pertain to all of the available functions and are just ignored. The color coded inputs match their respective functions at left.
    Let me know if you find any mistakes or bugs and I will try to correct them.
    One Other Thing....
    This wizard was designed to fit a native 1270 x 1024 screen which I use.
    If you are using a smaller screen it will be necessary to check The "Auto Screen Enlarge" Check box on the general config page of Mach. It will cause all screens to shrink or enlarge based on the resolution of your monitor.
    Edited attachment to remove the unnecessary system files that snuck in from my Mac
    Attached Files Attached Files
    Jul 2005
    969
    wow great and neat interface, definitely one of the nicest wizard out there if you intend on doing other for rectangular pocket or any other tool path i will certainly follow there progression.
    again great work
    ill ask for the post to be moved to the wizard section.
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    Jul 2005
    969
    what is the macosx folder for???
    Oct 2006
    51
    Sorry about that...
    Just delete the Mac folder. Those are Apple Mac indexing files. They are hidden System files...but they show up on a Windows PC. I will repackage it on a PC so they are not in there. Sorry for the confusion and thanks for the heads up.
    Andy
    Oct 2006
    51
    So sorry!!!
    I made some mistakes in the attachments.
    They would not run as posted. I have re uploaded the Attachments and they should work fine now. Please let me know if there are any other problems.
    Andy
    Mar 2006
    48
    Very nice wizard and well made interface.
    Thank you for your effort and willingness to share. Looking forward to more of your work along this line.
    Jul 2004
    442
    Very cool!
    You could add a finishing pass but it's great the way it is.
    Ozzie
    Waht software did you create the buttons with? It looks really good.
    Oct 2006
    51
    I considered doing a finishing pass into the routine but decided to put it off. It's possible that I may. I may also add a spiral plunge ability as well. Working on this wizard and a screenset that I have in the works has eaten up way too much of my time lately. I'm not getting a lot else done.
    Gerry, I used Photoshop for the whole layout. After I get everything where I want it I slice it up into buttons with one big image for the background. I have to create two versions, one for the on state of the buttons, and one for the off state. I have a little bit of background using Photoshop so it helps.
    Here also is the screenset I have been using. The circle wizard actually started out as page two in the screenset, and still is. I broke it out to be a stand alone wizard for anyone else. The screen is actually a little different from this shot.
    Because the Circle routines are actually a part of the main screenset it loads instantly so it's easy to create a roughing path then bounce right back and create a finish pass. All the values are still there.
    Andy
    very nice screen setup , thats got to be the best one that i have seen so far , its not missing anything
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Any tutorials (or links) on making buttons like those in Photoshop?
    Oct 2006
    51
    Hi Gerry,
    This is the tutorial that I found a few years ago that works pretty well.
    It obviously requires Photoshop. I don't even use all the steps in this.
    http://www.altuit.com/webs/altuit/Gl...lassButton.htm
    If you have any questions I can help.
    Actually I can make a simple layered photoshop file of a button.
    When you open it in Photoshop you can interogate the layers to see how it is put together. Actually much simpler than you might imagine.
    A sample file would be great. I've been playing with a different tutorial, but it's rather complicated. The one you posted looks to be much simpler. Thanks.
    Oct 2006
    51
    Gerry,
    Here is the layered Photoshop button file. If I can figure out how to do a good screen capture video I will do it.
    Andy
    Attached Images Attached Images
    Oct 2006
    51
    Gerry,
    I have posted a video tutorial up on YouTube if you are interested.
    Please don't be too critical as this my first attempt at a video tutorial.
    It was done on my mac. The screen resolution on mac is really high so it does affect the amount of movement on screen. I hope it helps.
    Andy
    PS If you watch this video at the YouTube site it is available in High Quality which is much easier to watch.
    [ame="http://www.youtube.com/watch?v=lGZpzFA4ICo"]http://www.youtube.com/watch?v=lGZpzFA4ICo[/ame]
    Can't thank you enough. 2 little things I was missing. Awesome.
    Oct 2006
    51
    Hey, that looks familiar!
    Mar 2007
    Love your new screen! It looks like the eye candy.set file is missing from the zip file if you would be willing to share it.
    Oct 2006
    51
    So sorry about that....I was up late putting that together. I had two readme files in there when one of them was supposed to be the set file. I have edited the previous post to include it. Here is the set file by itself.
    Sep 2005
    164
    Thanks, very nice work.
    Danny
Page 1 of 4 123
  1. Need Wizard
    By mungaro in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2008, 10:59 PM
  2. Hole wizard
    By villiersterrace in forum Solidworks
    Last Post: 12-18-2007, 10:47 PM
  3. Nesting Wizard, Mach3 internal wizard.
    By thuffner3 in forum Mach Software (ArtSoft software)
    Last Post: 03-05-2007, 03:38 AM
  4. Disabling Help Wizard
    By kentavv in forum Mach Software (ArtSoft software)
    Last Post: 02-20-2007, 05:40 AM
  5. Need Wizard/Screen Help
    By elalto in forum Mach Wizards, Macros, & Addons
    Last Post: 08-10-2005, 12:08 AM
