Often faults on this nature can be caused by the Power unit either not working or a short that shut the supply down.
The first thing I would check is measure the 5v or 24vdc out of the P.S. when powering up, if it comes up briefly, remove the 24vdc connections one at a time and see if the unit stays powered, if it does, it then track the source of the short on that conductor.
Do the same with the 5vdc.
Al.
