586,485 active members*
2,498 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Need a favor. STL converted to part file or solidworks part file.
    Nov 2008
    6
    Hi, i have been using the solid edge STL importer, and ive recently encountered a problem. My solid edge freezes up whenever i try to open an stl file with my STL Importer addon.
    Does anyone have this addon? If you do, could you please help me and convert it to a part file for me?
    I created this model in sketchup. If there is any other way, or workaround, to get sketchup to import to solidworks or solidedge, please let me know.
    Attached Files Attached Files
    Nov 2007
    79
    sw2007
    i converted them to sw2007 for u , i hope this gona help
    thnx
    Nov 2008
    6
    Thanks alot! The one thing thats bugging me is the triangles in the concave.
    This is going to be a clamping compression mold to make skateboards, and i think the triangles might leave impressions in the wood.
    Jan 2004
    3154
    The triangles are resultant of low quality settings in the program that saved the stl
    You will have to save it using a HQ setting or massage your surfaces in SW.
    www.integratedmechanical.ca
  1. converting a mastercam 9 file into a Solidworks file
    By Michael82 in forum Solidworks
    Last Post: 04-17-2009, 07:14 PM
  2. Part program file storage
    By JWLotz in forum G-Code Programing
    Last Post: 01-30-2008, 04:06 PM
  3. Converting ACAD DWG into Inventor Part file
    By phil m in forum Autodesk
    Last Post: 11-21-2007, 07:03 PM
  4. All sides one Part file
    By wmFlipper in forum GibbsCAM
    Last Post: 02-04-2007, 09:34 PM
