586,485 active members*
2,498 visitors online*
Results 1 to 20 of 30
    6855
    Micro Mark Mini mill converstion
    Well I'm finally done with my Micro Mark mini mill cnc conversion. I converted it it all ball screw and servo motor. I'm using Gecko 320 drives and camtronics power supply at 80 volt and 20amps. The system is geared 20:1 the ways were lapped and I replaced the gibs with brass.
    The z axles was machine from Ron steels plans, and modified for servos.
    Attached Thumbnails Attached Thumbnails 110_1042.gif   110_1043.gif   110_1044.gif   110_1045.gif
    6855
    Here are some pics of my z axis assembly.
    Attached Thumbnails Attached Thumbnails 110_1056.gif   110_1054.gif   110_1048.gif
    6855
    The belt pulley for the z axis is too big in dia and the motor for the spindle hit's it so I'm in the process of changing it.
    Jun 2003
    1365
    I assume you wont be running any coolant? Also, it looks like the X axis motor will be mighty close to the column? will it fit?
    Have you considered converting your spindle to belt drive? Its much quieter and you can calculate the speed of your liking to an extent. 3000rpm is great for that motor, I have taken .25" deep cuts with a 3/8" rougher on mine at about 2500rpm and the machine started chattering before the motor crapped out.
    Jon
    6855
    No problem with clearance everything fit perfect just the one belt pulley I have to change.
    I have looked every where for info on converting to belt drive, please share how to do it.
    2139
    Why the brass gibs?
    Eric
    I wish it wouldn't crash.
    6855
    Lower coefficient than the iron on iron. When I lapped the stock set-up what i found was I was just wearing away the metal and had to keep tighten the set-screws, with the brass that did not happen and because of that I ended up with no play in the x and y.
    Jun 2003
    1365
    I took my spindle and all that other stuff apart so long ago that I dont even remember how it all went together and all, but basicly when you take off the motor mounting plate, theres a spacer ontop of the top bearing and on top of that is the spanner nut, I think thats how it goes, What I did is cut the spacer down, made a pully that goes over it and use the spanner nut and tighten it down on top of it, I made a pully that I press fit onto the motor shaft and a motor mounting plate. I am making a new motor mount for my new motor along with new pullies.
    -edit- I too have brass gibs on my machine
    Jon
    779
    Paul,
    On your first post in this thread you said you have the camtronics box running the servos at 80VDC!!! Thoes Clifton servos are rated at 12-60 with a nominal at 36VDC. Are they getting very hot when you run at that voltage?
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    6855
    Yes I'm running 80vdc and no their not getting hot at all so far.
    2139
    They will only see the 80 volts when near stalled. Otherwise they see much less voltage.
    Eric
    2139
    Did you use the Mcmastercarr ballscrews? One nut or two per screw? Any backlash?
    Eric
    6855
    I used ball screws and nuts from roton. Their is no backlash since I used brass gibs, I could really tighten up the gibs.
    2139
    How much did they cost, if you don't mind my asking?
    Eric
    6855
    Quote Originally Posted by balsaman
    Eric
    http://www.cnczone.com/forums/showpo...04&postcount=7
    Apr 2003
    1873
    Paul do you have a link where you found a power supply for the Clifton servos ?
    Ken
    6855
    I got the power supply and box from camtronics http://www.seanet.com/~dmauch/ . I will post some pic later this week.
    6855
    Finally got my machine all together, looks great and so far is working very well. I will post some video and more pics when I get a chance, now I can start my laser project.
    Jun 2003
    1365
    you tease!
    sure, tell us all about it but make sure not to show any pictures!
    Mar 2004
    564
    Paul, What encoders did you use on your set-up?
    The Clifton motors I have came with renco encoders which I want to change....
    thanks
    kevin
  1. What size steppers for Grizzly mini mill?
    By Mini Miller in forum Benchtop Machines
    Last Post: 07-18-2005, 05:45 AM
  2. Capabilities of mini mill @ $2500
    By jl123 in forum Benchtop Machines
    Last Post: 05-14-2005, 03:59 PM
  3. custom mini mill
    By jimbo in forum Uncategorised MetalWorking Machines
    Last Post: 12-30-2004, 05:33 PM
  4. First Impressions for CNC mini mill conversion
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 11-17-2004, 03:37 AM
  5. New to Mill and CNC - Can you mix a Mini and Micro Mill
    By Sherpa in forum Benchtop Machines
    Last Post: 09-09-2004, 03:36 PM
