587,066 active members*
3,655 visitors online*
Results 1 to 9 of 9
    Mar 2007
    125
    On the CNC 4 PC breakout board
    I want to add spindle control to my lathe which is a monster motor on 120vac.
    I suspect startup amps are around 25 amps. What relay or contactor would I need to use to hook up to the cnc4pc board?
    24223
    Depending what you switching voltage is, a P&B, Potter & Brumfield PRD Relay series is a good alternative to going with an actual motor contactor.
    They come in 12v or 24vdc versions for low voltage control.
    A PRD-7DY0-12 is 12vdc coil with DPDT 25A contacts @ 270VAC.
    Al.
    Mar 2007
    125
    I've got 5vdc readily available, I think if I go with a higher voltage on the relay contactor, I will need an additional transformer, I was trying to avoid that if at all possible. 12 and 24dc and ac relays in this amp range are readily available at mcmaster, I was hopingsomoen here had been down this road before with the cnc4pc breakout boards. Thanks for your suggestion and any follow up information you might be able to add.
    24223
    If this is a Tower and not a Laptop, What is wrong with using the PC 12vdc from the P.S. 4pin sockets?
    Al.
    Feb 2007
    4553
    Smile
    Al,
    What about one of these?
    http://www.crydom.com//userResources...crydom_ha6.pdf
    http://tinyurl.com/5wks2g
    $8.00 Each + $6.00 shipping!
    Jeff...
    Mar 2007
    125
    Jeff, I ordered one of those, pretty good price! I will see if it works. If anyone else has any other suggestions, please add for those that come in behind me.
    Al, you are right, I did not consider all the 12 volt in the tower. Good suggestion.
    Feb 2007
    4553
    Smile
    Seanreit,
    A more elegant, however much more expensive solution would be a VFD.
    Hope the SSR works out for you.
    Jeff...
    24223
    A SSR should work also, but it is important to incorporate this in the E-Stop string, especially when using a S.S. device, also the E-stop should be hardwire activated.
    i.e. not by screen button etc.
    I know you can get away without following safety measures on a hobby machine, but the same dangers exist as found on a commercial M/C.
    Al.
    May 2005
    674
    The 12v from the PC will work fine.
    Or get yourself a Meanwell 12v/5v combo power supply. At $25 a pop, it seems pointless to make your own. The external supply will keep everything tidy in your computer tower.
  1. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  2. Which breakout board to use
    By erkiwi in forum Stepper Motors / Drives
    Last Post: 05-05-2007, 08:08 AM
  3. Best breakout board?
    By nate in forum Xylotex
    Last Post: 01-03-2007, 02:39 PM
  4. Breakout Board
    By bkkpool in forum CNC Machine Related Electronics
    Last Post: 07-28-2006, 07:15 PM
  5. Breakout board
    By joecnc2006 in forum CNC Machine Related Electronics
    Last Post: 06-29-2006, 03:33 PM
