586,419 active members*
3,329 visitors online*
    Oct 2008
    14
    belt driven CNC
    hi, im looking to build a lower priced cnc, im therefore looking into a belt driven machine, im struggling to find much information on them however. the imforamation i am finding im getting a bit confused with.
    will there be a torque loss with a belt design?, can you controll the stepper rpm or do i need to use a second belt to gear it down? should i even reduce the speed with a belt or simply a couple of spur gears?
    many thanks
    Attached is a picture of mine. For the belts and stuff I purchased them from here:
    http://stores.ebay.com/HUBBARD-CNC-INC
    Hope that helps.
    I did not need a second pulley at all. I have 2 8 wire 282 oz motors for the Y axis. 1 of the same for the Z axis. And a single 425 ox 8 wire motor for the X axis. I am using a 4 wire bipolar controller and everything works just fine for me.
    Just need to re-plain the top of the work area to be even with my cutter again. Today I rebuilt everything trying new designs but what I was trying didn't work. The machine works fine though.
    Please check out my CNC blog
    http://cncinside.com
  1. belt driven CNC table? (I have pictures)
    By rcbamm in forum DIY CNC Router Table Machines
    Last Post: 04-19-2014, 03:14 AM
  2. Spindle Lock for Belt Driven X2
    By dleroi in forum Benchtop Machines
    Last Post: 01-30-2008, 01:37 AM
  3. Belt-transmission driven cutters, any good?
    By boggyplanet in forum CNC Wire Foam Cutter Machines
    Last Post: 02-23-2007, 03:33 AM
  4. Belt driven screw ?
    By tomcat47 in forum Linear and Rotary Motion
    Last Post: 01-29-2007, 05:20 PM
  5. Converting a mini from geared to belt driven
    By cncadmin in forum Benchtop Machines
    Last Post: 11-04-2004, 05:15 PM
