586,437 active members*
3,672 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Cheap 1500W Chinese spindle, experiences?
Page 1 of 68 1231151
Results 1 to 20 of 1344
    Mar 2004
    392
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=015
    Does anyone have any experience with this spindle or have comment?
    I have a homebrew aluminium gantry router with a 3HP round body Dewalt router for the bigger jobs but I have started to do lihtophanes in acrylic and some aluminium jobs as well so I am looking of a small powerfull highspeed spindle.
    Mar 2004
    392
    Nobody had their hands on one of these then?
    If I buy one (see if I can wrestle the money off the wife) then I'll post some information.
    I am going to contact the seller and see if they can provide some more pictures and info.
    You are aware that you'll need a VFD to run that, right?
    Oct 2006
    323
    Included in the price
    Gerry,
    Surprisingly that listing says 'inverter/controller' included in the set.
    Carry on soldier, and report back.
    Yep, I missed that when I glanced through. That's a pretty good price, then.
    Mar 2004
    392
    According to the seller he is currently having the manual and spec sheet translated and will be posting this info on the auction.
    I'll keep my eyes peeled for this.
    Mar 2004
    392
    http://cgi.ebay.co.uk/a-air-cooled-s...742.m153.l1262
    The seller has now loaded some more pictures, looks very interesting.
    24223
    I see someone got one with high run-out, but he promised to put it right.
    You could contact one of the previous sellers to find out their experience.
    Al.
    Mar 2004
    392
    That's a good call AL, I think i'll do it as I am considering one of these spindles.
    It looks like this is a KL-1500 cnc spindle that kelinginc use on their machines.
    Jan 2007
    32
    Al.
    I too am considering one of these spindles, however have been bothered by the lack of experience. I contacted every user that had posted feedback for a spindle and have heard back from two.
    I actually purchased the .8Kw spindles. Three of them. We have about 160 hours on the first spindle. There is no data or instructions included in the package. This is not a problem for the spindle but the features of the inverter are unavailable. Not a problem if you only want to run at one speed and don't want to be able to turn on or off remotely. We have orderd ac inverters from Automation direct. We use the spindles on an internal grinder and run at 24000 rpm. My only ***** is the collet is to be an ER 11 but the ER 11's we can buy in the states do not match the spindle nut. The included 6mm collet works fine but we need a 1/4 inch collet for our grinding pins. I have purchased an air cooled from another Ebay vendor and it was crude in comparison to the water cooled spindles. The water cooled spindles should work great for a router. The spindle is actually nothing more than a 400hz three phase 2 pole motor with a hollow shaft to accept the collet. When the bearings fail they can easly be replaced with as high a quality as you desire. If you can obtain english instructions for the inverters they are an ok value. Also if you obtain instructions please pass them on to me. I have two that are not being used for lack of instruction.
    and the second member
    I am still in the drawing stage for my machine and have not had time to fire up the spindle yet. The components themselves look to be of decent quality but I will not be able to give a real answer until I start cutting which should be by the end of January. I was a little unhappy with them describing the collet setup as ER20 when in fact it is an ER16 setup with a max shank size of 10mm.
    You may well find the following website useful
    http://www.cnc-technik-madreiter.at/
    This is a European company using the 3kW version of the motor in a range of machines. This unit does have th ER20 nose if you require this. I think you may be able to get it direct from the following company ( I found them after doing some post auction research )
    http://www.made-in-china.com/showroo...3-0KW-20-.html
    You can also find these units (2.2 kW) in the States at something of a mark up from the following
    http://www.kelinginc.net/CNCSpindleandController.html
    All that said the spindle appears to be in use on a number of the smaller Chinese ready built CNCs and can really only be considered a bargain at the price. I can live with the 10mm shank size for the uses I have in mind.
    I received no setup instructions for the freq, however after a bit of digging I have found a PDF of the manual. You will need a braking resistor and possibly a set of HF filters, I am checking on this at the moment.
    I am going to try to get a copy of this manual too and will post a copy if it do. If it is in Chinese I live with an exchange student who can translate most of the information anyways.
    I am most concerned about the collet issues, i am considering the 2.2Kw spindle and would expect it to come with an ER20 collet. I messaged the manufacture.
    Yes, we can grarantee that this spindle with ER20 COLLET. We have two types of collets ER16 AND ER20 for this kind of spindle motor.
    We Also have 3kw water-cooled spindle, The Best price: 460.00 USD without VFD.
    But the shipping cost is higher to your place: 118.00 USD because it is too weight.
    I also emailed him asking about any guarantee or warranty on the spindle.
    The spindle is similar to the Keling.
    Yes we Guarantee on the spindle for repairing free in our domestic market.
    But the shipping cost is much much higher for world shipping.
    Thank you very much for your understanding!
    I am finding more and more information but what bothers me is inconsistencies and things that could get lost in translation. I might try to get my room mate to email him and see if we can communicate better in native language for them, he declined providing me with a phone number because his oral English is too weak.
    However what bothers me the most is this. The ebay auction for the 2.2 kw spindle states dimensions of 80x210mm, looking at the Keling website, there 2.2Kw spindle has dimensions 100x252mm. Now looking at the ebay vendors other spindle listings i see the 3kW spindle supposedly has dimensions of 100x250mm!
    http://cgi.ebay.com/2-water-cooled-8...742.m153.l1262
    Even the made in china link posted does not have consistent information with these other listings. I just want a way to insure i will receive a 2.2Kw spindle with an ER20 collet...
    So this was a long post, when your done digesting all this let me know what you think. My room mate will be back in China over the holiday break so i may want to take advantage of that to same on some shipping.
    ~Tyler
    Jan 2007
    32
    I just ran into a good thread over on a wood working forum, some satisfied customers and some information about the VFD's. However once again there is some talk of wrong collet sizes being received.
    I think i am going to have to directly let the seller know I want an ER20 collet if / when making the purchase and have paypal back it. Anyways take a look if you want.
    http://www.woodworkforums.com/showthread.php?t=75846
    May 2006
    94
    chinese spindle
    I have one of the 2.2 kw water cooled on order now too, after being assured it is an ER-20 collet. I"ll let you all know how it works. I didn't get his inverter, so I can get support for inverter. Probably buy from Factorymation (They're Chinese made too.....). Actually that combo is cheaper than his! I'm concerned especially about electrical interference from VFD on the xyx motion. If anyone has done an installation of this kind and can recommend paraphenelia to minimize those problems I"d love to hear about it.
    1050
    Hi Folks,
    interesting to know the interest around Asian spindles - I am planning to go for one before january.
    Take a look at this thread
    http://www.mechmate.com/forums/showthread.php?t=1008
    the argument about the 2.2KW spindle being 80mm dia has even baffelled me ! but any way i am going to try.
    A delta make VFD js going to cost me less than a Chinese imported so I am going for it.
    The way they recomend a 2.2KW VFD tells me that the spindle is not a true 2.2KW one.
    anyways if it works then ok
    RGDS
    IRfan
    Jan 2007
    32
    Cool,
    So I think this confirms my buy of a 2.2Kw with now VFD, i plan on building my own anyways. I just want the ER20 spec confirmed.
    endgrainguy, not to use you as a ginue pig but i want to see you receive an ER20 colet first after being assured.
    Does anyone know what size spindle waynec is using on that mech-mate forum? It looks like a smaller one, im also interested in the wiring connection, it looks like a round 4 pin connector that im hoping will be provided.
    Jul 2003
    36
    I believe the spindle that waynec is using is from HomeshopCNC which is rated at 2.2Kw. In fact I just received my spindle from HomeshopCNC this week. It has a 4 pin connector on the spindle and comes with the mating plug. I purchased just the spindle from HomeshopCNC. I purchased a G2 VFD from Automation Direct. It will be about a month before I have my spindle in operation. I am in the process of gathering parts for my CNC build which I hope will begin around the beginning of January.
    Sam
    My new blog
    Jan 2007
    32
    Hmm ok, i guess it just looked a little small in the pictures and it didnt have the black ends.
    So has anyone here received a spindle from the ebay seller that was mentioned originally in this thread. I am trying to get beyond the fact that these spindles are half the price of the Homecnc and Kelinginc ones.
    It does cost $45 shipping from china but i dont understand how it can just be marked up that much.
    Jul 2007
    265
    Very interesting!
    Is the rpm variable with these spindles? Do they try to hold the rpm constant?
    Jul 2003
    36
    tgrandahl
    I spoke with Rick at HomeshopCNC because the spindle I received looked a little different than the photo on the website. The photo on the website is an old model the new spindles do not have the black band around the ends. The spindle I received is stamped with 2.2Kw 7.6 amps 220 volts 3 phase.
    tahustvedt
    The VFD allows you to vary the speed of the spindle. This can be done from the front panel of the VFD or using a 0-10v signal fed to the VFD.
    Sam
    Jul 2007
    265
    Ok. Thanks.
    1050
    Well the cost is all in the bearings - if you put in ceramic P4 bearings then the cost of the bearings is as much as the spindle!
    its all a bit of compromise I think.
    I just ordered a 2.2KW 8 AMPs from HK - China - cost me around 300USD, I am assuming it has steel ball bearing - ones those give up I need to move em upto something better P4 graded.
    after all routers screaming at 24K rpm dont have ceramic ball bearing.
    so I am assuming its worth a try.
    I have ordered a Delta VFD to run the spindle.
    RGD
    Irfan
  1. Cheap and Simple ATC for Chinese Spindle
    By bogan in forum Spindles / VFD
    Last Post: 07-27-2018, 05:42 AM
  2. Chinese Spindle Experiences
    By analogman in forum DIY CNC Router Table Machines
    Last Post: 03-29-2013, 02:02 AM
  3. Cheap chinese spindle modifications - Generic
    By speedydumpster in forum Benchtop Machines
    Last Post: 03-28-2013, 04:28 PM
  4. Porter Cable or Cheap Chinese Spindle?
    By 777funk in forum DIY CNC Router Table Machines
    Last Post: 01-21-2011, 08:15 PM
  5. Connecting a hitachi VFD to a cheap Chinese Spindle
    By zigmart in forum DIY CNC Router Table Machines
    Last Post: 11-26-2010, 07:35 PM
