586,781 active members*
3,009 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > How to read a IGS with vb.net/C#?
    I am wanting to play around with CAM using vb.net or C#. Can anyone give me any direction on where to get any info on this. I have no idea how read the IGS info.
    Donald
    Apr 2008
    1577
    The latest standards that I am aware of can be found here. It is a full specification in PDF format. It is a large file.
    http://www.uspro.org/documents/IGES5-3_forDownload.pdf
    Oct 2008
    41
    There is a project - "Monocam", which is based on C# and Mono. Don't know about
    IGES, but it probably reads STL. Look it up in old posts.
    Jul 2005
    181
    Have you ever looked at the contents of an IGES file? It couldn't be more poorly laid out and hard to read if it had been a binary format. If I were you I'd try for a more easily understood format. Even SAT files are easier to understand than IGES.
    However, IGES has been a standard since before Moses so you are likely to find source code all over that attempts to make sense of it.
    Mar 2010
    I too need it...
  1. My CNC doesn't read G02 X Y I J
    By Bazz in forum G-Code Programing
    Last Post: 10-07-2008, 03:40 AM
  2. 10T-F READ READ READ READ READ READ
    By dcoupar in forum Fanuc
    Last Post: 03-27-2008, 11:39 PM
  3. Read ahead
    By M-man in forum Fanuc
    Last Post: 05-10-2007, 03:07 PM
  4. Must Read for All
    By CBNDude in forum News Announcements
    Last Post: 07-22-2005, 03:14 AM
