586,675 active members*
2,930 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cleaning coolant stains from collets etc...
    Apr 2004
    353
    Has anyone ever had any luck removing the blackish coolant stains from their collets or milling tables?
    Sep 2008
    199
    No Luck really Removing the stains, But after everything is coated in coolant and i wipe it all up as well as possible I spray everything with a Coat of LPS 1 and that has seemed to slow signs of any stains, and slows rust too. Don't know if that helps you but I'm interested to see if anyone has any solutions.
    -JWB
    --We Ain't Building Pianos (TCNJ Baja 2008)
    Jul 2005
    12177
    Quote Originally Posted by laka View Post
    If the coolant stain will not wash off with either acetone or methanol don't go any further because it is actually etched into the metal. This is particularly the case with the black stains that form under vises and things bolted to the table for a long time.
    You could polish it off using Scotchbrite but in doing this you are removing metal and this is definitely not a good idea.
  1. Coolant stains on aluminum
    By JpBinc in forum MetalWork Discussion
    Last Post: 12-19-2016, 11:42 AM
  2. Removing coolant stains from clothing?
    By Cyre in forum MetalWork Discussion
    Last Post: 03-18-2007, 03:47 PM
  3. Flushing/cleaning coolant reservoir?
    By speedofsound in forum Milltronics
    Last Post: 10-26-2006, 04:01 AM
  4. Way stains Normal?
    By Dan S in forum Mini Lathe
    Last Post: 09-27-2006, 09:50 AM
  5. Coolant/oil.... what about part cleaning? Any books?
    By InspirationTool in forum MetalWork Discussion
    Last Post: 08-16-2006, 07:43 AM
