Hi Gary,
This is Ramesh from Comstar from Chennnai, Inida. We are the leading manufacturers of Starter and Alternators. Formerly known as Visteon Power train controls india ltd.
We had a issue of Humming noise in Starter motor. Can you guide me to solve the issue.
At present we suspect the balance of Atmature in Starter. By trial and error method we found, when we use the armatures w/o balancing it give similar humming noise. But we have same humming noise even the armatures get balanced.
What could be problem for humming noise ?
Thanks with regards,
P.Ramesh
