Originally Posted by
EvanZ
no limit switched as of yet, but they are just jumped, so NC. The E-stop I donno but I will just try to emulate it in Mach three and see if it still trips.
Evan
I belive there is a setting called debounce or something similar in mach3. It sets the time before mach will recognise a signal as valid. This will prevent spurious signals from geting in. I think that the default is set very low and you can bump it up significantly to help solve this problem. You don't want to set it to three seconds or something silly, but try doubling the setting that is there and see what happens.
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
