586,504 active members*
3,305 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > SL-10 leaking like an old dog?
    yeah, just got a brand new SL-10 with the bar feeder. Does anyone else have one that leaks half of its paltry coolant supply all over the floor? I think it's coming from somewhere near the headstock/auger drive. The Haas tech came out, tightened some bolts, added some caulk and went away. It's no better.
    http://onedropyoyos.com/yoyos/
    Jul 2005
    12177
    We did have one that did that, and it was at the auger drive, and it was necessary to caulk and tighten a few bolts.
    BUT first it was necessary to take off all the sheetmetal above the auger down under the headstock and clean all the coolant out to get at the bolts that needed tightening; the loose bolts were below the waterline when the machine was completely full of coolant.
    If your Haas tech did not all of this then maybe the wrong bolts were tightened.
  1. Leaking coolant reservoir
    By JTulley in forum Tormach Personal CNC Mill
    Last Post: 08-03-2008, 02:51 PM
  2. fiberglass gas tank and leaking.
    By krymis in forum Composites, Exotic Metals etc
    Last Post: 07-28-2008, 01:03 PM
  3. Haas TM2 Leaking Coolant
    By Chris Swier in forum Haas Mills
    Last Post: 06-21-2008, 03:57 AM
  4. thru spindle coolant leaking
    By GARY DAVIS in forum Fadal
    Last Post: 03-25-2008, 01:28 PM
  5. Air/Hydraulic leaking problem??
    By bherr in forum Bridgeport / Hardinge Mills
    Last Post: 06-20-2007, 04:50 AM
