Could be CR...just got the kit a few months ago.
Kalvin....the tub idea is okay...just frame it in with some plywood and add some of that expanding foam....and you can use the frame to support a full enclosure. I built mine using the Hoss's ideas and MRC's dimension (which were a bit off). I should have used at a minimum a 36 inch depth, the width at 48 inches. If you're doing a full enclosure and plan to work items wider then the X3 table, then plan for some plexiglas windows on the sides of the full enclosure.
Paul
