587,048 active members*
2,749 visitors online*
    Nov 2004
    Need help on Hitachi Seiki error 1012
    Looking for some troubleshooting help on a VK55 with Siecos III control. Started with NUMC error 1118 infrequently, then error 1012 infrequently. If I cycle power the error would clear. Then after a while whenever I powered up I got the error. I had the NUMC board replaced and that did not solve the problem so the original NUMC was put back in and a SAMS board was ordered. As anyone with a Hitachi can tell you this took weeks. Installed the SAMS board and I'm off & running.......for 3 weeks, then error 1012 returns and I'm down agian. After many weeks and many service attempts, they say the SAMS board is bad and we order another one. Install the SAMS board and there is no change. Still error 1012. If any of the Guru's out there could throw me any possible causes or thing to check it would be greatly appreciated. Thanks in advance for your experienced input.
    Nov 2004
    36
    1012 Error
    The Seicos III control is a Micon 16-3 system. The Error you are getting is a cpu alarm.
    I own a small service bussiness in Wichita Kansas called KMTS. Please call me at 316-744-0549 and I'll help you get that cleared up I have over 10 gig of Hitachi Seiki info in my database and have been working on them for years!! This is no problem.....
    Josh
    aka Hitachi_man
  1. Hitachi Seiki Service and Support!!!!!!!!1
    By Hitachi_man in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2024, 12:29 PM
  2. Akira seiki
    By HTMTRADER in forum Uncategorised MetalWorking Machines
    Last Post: 03-18-2010, 11:04 AM
  3. Haas rotary table on vertical Hitachi Seiki
    By smoggy in forum Haas Mills
    Last Post: 05-18-2005, 06:57 AM
  4. Hitatchi Seiki VS-40,50 camunit
    By jjmachine in forum DNC Problems and Solutions
    Last Post: 11-02-2004, 11:38 PM
  5. Hitachi Seiki MH 400 drawbar tension
    By kmuller in forum Uncategorised MetalWorking Machines
    Last Post: 11-07-2003, 08:10 PM
