Machine: K2cnc 2514 with .1 lead screw
Motors: Keling steppers 425 ozin 4.17 V 2.8A
Controllers: Keling 4030 max input voltage 40V max current output 3A
Mach 3 software
Power supplies: 36V 8 A for X and Y axis
36V 8A for Z axis
All axis in Mach 3 are set up for velocity of 60ipm, accel 3.5.
Resolution currently set at 4000.
No matter what microstep I use, these appear to be the maximum parameters before the motors start slipping.
Keling has suggested that I use 1/8 microstep, but it does not improve it.
Mechanicals appear to be fine: no binding, etc.
I am down to the following options:
A. 48 V power supply and larger controller
B. .2 lead screw
C. more powerful computer ( can it be that I need a higher frequency pulsing?)
C. give up
I am cutting mostly balsa, so I need more speed.
thanks in advance.
