587,006 active members*
2,899 visitors online*
Results 1 to 7 of 7
    Feb 2008
    19
    Water based coolant - suppliers in Australia?
    Hi
    Does anyone know where I can buy Greencut or KoolMist or an equivalent product in Australia. Both compunds are completely water based and do not leave any oily residue like soluble oils (we are drilling powder coated sheets and cleanliness is a priority). I have contacted the suppliers in the US with no luck and would be grateful if anyone knows where I can buy here.
    Thanks!
    Dec 2006
    277
    G'day Leon,
    Edit: Just read it again and it is coolant my answer is no good
    Cheers, Bob
    http://www.ocm.com.au/wordpress/
    Feb 2008
    19
    No worries Bob, I can see the potential for confusion. We are after a water based cutting fluid/coolant but I will check out your earlier link about the water cooled spindles. Cheers
    May 2007
    26
    TrY Fuchs lubricants located in Melbourne,
    We use there stuff on our Haas, no corrosion and water based
    Feb 2008
    19
    Thanks! I checked out their website and they have a range available. Can I ask the name of the product that you use - it might save me some time trying to compare the different features. Thanks again
    Leon
    May 2007
    26
    OK product is Ecocool 68 CF2
    Feb 2008
    19
    Thank you! That is much appreciated.
    Leon
  1. Is water based
    By cncadmin in forum Safety Zone
    Last Post: 10-19-2022, 05:10 PM
  2. Water Based Coolant
    By classictom in forum MetalWork Discussion
    Last Post: 08-27-2008, 12:04 AM
  3. Coolant, mixing in more water
    By smellyfeet in forum Uncategorised MetalWorking Machines
    Last Post: 06-30-2008, 12:39 PM
  4. Coolant - Oil based or Synthetic?
    By apeman88 in forum Uncategorised MetalWorking Machines
    Last Post: 04-22-2008, 04:26 PM
  5. Water-based coolant/lube use and handling
    By jim_stoll in forum Benchtop Machines
    Last Post: 11-13-2007, 07:49 AM
