I want to do a small production run of parts which involves doing a few countersunk holes and a profile around a 2"X6" aluminum plate that is .75" thick. The holes don't take too long but the profile does. I am running at probably 3K rpm with a .5" HSS end mill (2-flute) doing 5.5 IPM or so with a DOC of .5. It works OK but I get some chattering and my finish pass of .015 leaves some nasty marks unless I come over and turn the RPMs down just before the finish pass starts (which is too slow for the profiling). Would switching to a carbide end mill allow me to increase the feed or DOC and get a good finish? It currently takes 45 minutes or more for one piece and I would really like to lower that as much as I can but I don't want to spend $50 on an end mill that will be no improvement over what I have.
thanks,
Kevin
