I have a backup file of my parameters that I need to load onto a fanuc ge om, which is hooked to a komo vr 805q . The file is a TXT file and I was told that I need to setup communication with the pc, and then load it the same way I do a regular program. The problem is, I am currently stuck in MDI and have alarms 417 427 437, and it is flashing not ready, so I cannot load it the way I usually load a program. Is there a way to load the parameters while in MDI? I think the time it takes to type in each number could all be wasted if I mess up a single number, so any and all help would be greatly appreciated.
Thank you,
Alex.
