586,246 active members*
3,562 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver?
    Oct 2007
    76
    Lightbulb Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver?
    Hello Everyone,
    I'm designing a 50V 8A+ Bipolar Stepper Motor driver. I'm new to Discrete H-Bridges and plus I'm not very familiar with all the new MOSFETS and MOSFET Drivers in the market. I was wondering if you can share your experience with MOSFETS and MOSFET Drivers.
    So far the Drivers I came across are
    • Intersil HIP4082
    • IRS2304
    • Microchip TC4424
    And The MOSFETS
    • STF40NF06
    • IRFZ24
    • IRFZ44
    • IRF9530 and IRF540
    Well I came across plenty of other parts as well. Lets jus say the more U seek the More U find in this case. Just before I decide on one part I come across another which seemed better(btw My knowledge on MOSFETS is Very Limited. So cant really say if its Really a Better one I jus found). So I was wondering if someone can help me pick the right Driver and MOSFET for a Driver with the following Specs
    • Dual H-Bridge (MOSFET) Bipolar Stepper Driver 8A+ @ 50V
    • Step Sequencing will be done using a PIC or Atmega uC
    • Step Rate will be in the range of 2000-3500 Pulses/Second
    • Current Limiting is done using an External PWM @ 20kHz
    Please Advice!
    Thank You.
    Joe!
    Jun 2004
    487
    Hello Joe,
    My two cents: I've used the HIP4081A which is similar to your choice. I had a hard time getting rid of a sneaky current loop so I would recommend you watch out for proper layout and use a single ground return point.
    As for MOSFETs - and I'll likely draw the ire of some here with this comment - I'd go for the lowest RDSon on a rated device. Highspeed, etc are not that important in this application. Keeping in mind also that voltage rating should be high enough to account for motor back EMF and a few techniques like a parallel diode across the FET input resistor helps drain it quickly and avoid cross conduction.
    I like Atmel micros better than Microchip's but that might be a moot point soon if Microchip succeeds in gobbling up Atmel. Doh!
    JR
    Oct 2007
    76
    Thanks JR for your input
    I was told IR2104 and IRF540N is a well tried n tested pair to use in H-Bridges. I'm currently looking at using them in my driver.
    Please share your experiences using the IR2104 and the IRF540N.
    Thank You,
    Joe!
    Jun 2010
    i vote for 540 and irs2104
    b.r
    May 2007
    Hello Everyone,
    i am looking to bild H-Bridges.stepper driver using IR2184 and IRF540N anyone can help me
    thank
  1. L297 with MOSFET H-Bridge
    By joprinz in forum Stepper Motors / Drives
    Last Post: 01-13-2016, 08:04 PM
  2. Mosfet Driver
    By tivoidethuong in forum CNC Machine Related Electronics
    Last Post: 01-19-2009, 04:20 AM
  3. mosfet h-bridge design
    By visky in forum CNC Machine Related Electronics
    Last Post: 06-11-2008, 09:51 PM
  4. Experiance with the HIP4082 mosfet driver?
    By AbSat in forum CNC Machine Related Electronics
    Last Post: 07-02-2007, 12:17 AM
  5. IR2184, HIP4080A, or other for mosfet driver?
    By originator in forum Stepper Motors / Drives
    Last Post: 11-03-2006, 04:31 AM
