Hello
I bought this mill a couple of years ago and have not used it in a year.
I went to change tool and nothing happened. It has the two buttons at front you push one to tighten/ one to loosen, What should I check first. Switch,fuses ect. I am not very familiar with the controller. Mitsubishi Meldas "graphic gl" I do not beleive there is anything on the controller side that needs to be set before I can change tool. Anyhelp would be appreciated. Thanks
