586,597 active members*
3,483 visitors online*
    Oct 2006
    10
    removing nut on x axis
    Stupid question. I received a new bearing housing and new bearings for my syil sx3 x axis ballscrew. Can't get the preload nut off to replace them. Am I doing something wrong or what?
    Kevin
    Oct 2007
    166
    I doubt you're doing anything wrong. Possibly on here I made the comment that it appeared that someone had been swinging off the spanner when they tightened the one on mine. Trying to use the flat on the end to stop the ballscrew from turning was a waste of time.
    Mar 2008
    3655
    With a cutting disk, you can cut a slot into the end of the ball screw. Then use a common screwdriver to hold the screw while you unscrew the nut.
    CR.
    Oct 2006
    10
    Thanks for the advise. I thought maybe I had lost it. I will cut the slot in the end of the ball screw.
    Kevin
    Dec 2007
    413
    If you have a lathe, just grip the ball screw in the 3 jaw.
  1. Removing 4th Axis from Table, Fanuc 0i
    By Jay Kyle in forum Fanuc
    Last Post: 08-10-2022, 03:04 PM
  2. Removing Tooling
    By Mooser in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2008, 03:16 PM
  3. Removing a Gecko
    By sploo in forum Gecko Drives
    Last Post: 12-11-2006, 11:51 PM
  4. Removing nut off ballscrew, I've never seen anything like it
    By geohot in forum Linear and Rotary Motion
    Last Post: 12-24-2005, 04:53 AM
  5. Removing the armature ?
    By Ken_Shea in forum Servo Drives
    Last Post: 10-10-2005, 08:40 PM
