586,446 active members*
3,517 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Looking for small "blind hole"? clamps
    Apr 2005
    81
    I"m trying to find blind hole clamps that are between 1/8" and 3/8". Mcmaster has smaller ones but not the larger size i'm looking for (mcmaster part 5099a) What are these actually called and any ideas of where to find another source?
    Jun 2007
    3757
    Question Try Aircraft people.
    Aircraft maintenance / builders use all sorts of blind clamps.
    They call them sheet holders.
    Try clecos
    http://www.yardstore.com/browse.cfm/2,427.html
    I am guessing that's what you need.
    Apr 2005
    81
    will these "clecos" clamps work for blind holes or will they only grab two thin layers? I am trying to hold a piece of sheet metal to a blind hole drilled into a block of material. This would just be temporary and would have to be easily removed later. Any other options for something along these lines?
    Sep 2005
    1660
    Cleco's are not used in blind holes but rather 'thru' holes in two pc's of sheet.. work great in that application but I've never seen them used in a blind hole.
    Not sure what to recommend for locking into a blind hole. I'm sure some old machinist will jump in and give you the old school way of doing it.. :-)
    JerryFlyGuy
    The more I know... the more I realize I don't
    Jun 2007
    3757
    Talk to aircraft merchanic.
    The cleco work by having to blobby end that wedge when springloaded up a middle stem. They need special pliers to use them. Used for sheetetal. Limited range and not very high clamping force.
    There is another sort (might be avdel - can't remember) that are a bit stronger and they have a half stem with a step that goes through the hole and another halfstem that is stepped and threaded.
    You loosen the stem, push it through the hole then tighten up the knurled nut. They can be made quite tight and I have seen them in bigger sizes.
  1. Determining "speed hole" spacing and size? (weight saving cutouts)
    By douglasco in forum Mechanical Calculations/Engineering Design
    Last Post: 08-04-2008, 09:26 PM
  2. Replies: 6
    Last Post: 06-24-2008, 01:14 AM
  3. boring a .875" hole 3" deep in 304SS
    By mc-motorsports in forum MetalWork Discussion
    Last Post: 04-15-2008, 08:57 PM
  4. Questions on building small (18" x 24" x 3") machine
    By bikedude880 in forum DIY CNC Router Table Machines
    Last Post: 08-01-2006, 03:04 AM
  5. Smallest "clean" hole size?
    By Scratch in forum Waterjet General Topics
    Last Post: 06-24-2006, 04:15 AM
