586,911 active members*
4,347 visitors online*
Thread: motor wiring
Hybrid View
    May 2006
    44
    motor wiring
    I have a Bodine speed reducer motor that I can't get any info from the company,they claim they no longer support this model. It is type:nci-34rh,115v a c.rpm=1725,hp=1/15,60 cyl and 44 rpm at the reducer. It has four lead wires( 2black,2blue). How do I wire this motor to run? I tried different combos but no go. Did I fry it? I am trying to use this in a woodworking application. --- thanks ...joe
    24223
    Being AC it probably has a start and a run winding, check the continuity of all leads and see if they show as two separate windings, if so you will need a start capacitor in series with the start winding.
    See if Bodine will give you tha Cap. rating.
    Al.
    May 2006
    44
    The plate on the motor say use 5 mfd capacitor.What is the purpose of the capacitor? What does the wiring diagram look like? Is continuity checked by using the buss feature on the meter? ---- joe
    24223
    Rather than explain there are severl sites that outline split phase motor.
    e.g. http://www.iprocessmart.com/leeson/l...se_article.htm
    If you use the ohm meter range, test the for two distinct windings, when all four leads are brought out, it is to aid in reversing the motor.
    You need a 5 mfd AC rated capacitor.
    Al.
  1. motor wiring
    By cueshark in forum CNC Machine Related Electronics
    Last Post: 06-13-2007, 04:25 AM
  2. Can anyone help me with the wiring of the motor?
    By Darc in forum Stepper Motors / Drives
    Last Post: 08-17-2006, 03:57 AM
  3. SLO-SYN motor wiring info
    By dertsap in forum Stepper Motors / Drives
    Last Post: 12-01-2005, 10:47 AM
  4. Motor wiring again (sorry Al)
    By kong in forum CNC Machine Related Electronics
    Last Post: 06-10-2005, 07:49 PM
