586,608 active members*
3,638 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Oct 2004
    2
    Angry Heidenhain Tnc 430 Post Processor
    Hello everybody.
    In the shop i'm working to,has been installed a 3 axis milling machine with
    a HEIDENHAIN TNC 430 controller.As i read in the manual
    this is not so similar with other contollers which are familliar to me(like YAZNAK FANUK OKUMA).As i use mastercam 8 for creating iso code files(G code)
    i tried all the default post processors of mastercam to generate g code
    but the result was pure.Is there a colleague whom i can speak with, about this matter and others like 'creation my own post processor ' for example,
    and their opinion about using or not the HEIDENHAIN'S or MAZATROL's controller software for creation programs running on the corresponding controllers.(HEIDENHAIN 430 and MAZATROL NEXUS lathe milling are the kinds we have in shop).
    Personally i prefer iso g code programming but there is a pushing from above
    to use the specific software of the above controllers for programming.
    As a new member of this forum i'd like to note that any other messages for
    relevant matters are welcome.
    Waiting for reply
    kind regards
    Apr 2004
    34
    Post TNC 426/430 Post for Mastercam
    Dear friend, I wrote a very good post for Mastercam, and I willl stay glad to share with you.My post do all drill cycles in command, helical circular interpolation, and arcs in all planes: XY/YZ/XZ.
    I have tested this post extremely, so, I ensure for you that it´s a excellent post for heidenhain 426/430 systems.
    If you want test, I´m putting in attach with this message.
    The only problem is that was wrote for V9. I start in V8, but make some changes for V9.
    Hope that helps.
    If works for you, let me know.If not, let me know too.Maybe I can help you with the problem.
    Read the header for additional notes, about the resources included in post.
    Any doubt, contact me.If necessary, I do the changes for the post to V8 again.
    Regards
    Daniel
    Attached Files Attached Files
    May 2008
    2
    Im going to use your post
    thank you for posting that post I have A guy over from Iceland and he is now using mastercamm but could not find that post.
    Thank you
    Quote Originally Posted by CAMFUN View Post
    Hope that helps.
    Regards
    Daniel
    Mar 2009
    3
    Quote Originally Posted by gjames View Post
    Thank you
    Dear Daniel
    Please post your postprocess so that I can try it machine
    Regards
    Shajee
    Apr 2009
    10
    Unhappy mastercamx -TNCremoNT
    HI !
    i've rescently acquired TNCremont to send files to a TNC426HEIDENHEIN control.
    i'm trying to use it with mastercamX but i'm unable to postprocess with TNCREMONT.
    codes are not "G" but "L" like: "L X-11 Y0 FMAX"
    can some one tell me how to configure it ?
    i'm very new to this stuff, and i've been working on that machine since 6 months, i work files at home so they can be ready the day after, so i'm trying to make it work with my PC. My bosses dont seem to know how to do it...
    THANKS!
    Jun 2009
    3
    4 AXIS HEIDENHAIN MASTERCAM V8
    HI I NEED HEIDENHAIN POST TNC 430 4 AXIS MASTERCAM V8 PLEASE....
    [email protected]
    Oct 2020
    1
    Re: TNC 426/430 Post for Mastercam
    Do you have a version of this post that will work in a later version of Mastercam? X9, 2018, 2019, 2020 ???
    Sep 2003
    72
    the heidenhain controller can be used in both heidenhain language and also g-code programming.
    you can also programm the controller directly at the machine as it is very user friendly.
    Jun 2005
    2
    Nevermind
    Apr 2003
    372
    When I operated the TNC 426/430 controllers, I had access to mastercam but rarely used it. Like mouldmaker said, it is a very friendly system. Once you get to know the language, you will do most of the programming at the control, in most cases it is quicker than mastercam. I even used to do a lot of basic 3D stuff at the control using and combination on plane swapping and the "Q" (parametric programming) functions which allow you to have the program calculate variables in a flash. One program I wrote for a previous company is still used today. They are manufacturers of jigging tables for fabricators. The tables have 100's of holes in them and range in 100mm increments from 1m x 1m to 3m x 3m. All the operator has to do to machine the specific size the customer ordered, is to answer 6 questions at the beginning of the program and the entire program self adjusts. Get into it, heidenhain is great stuff, you and the push from above won't regret it, and besides, use the oportunity to learn a new language while you can, as it will boost your position in your current job and also your future employability by others.
    Good luck with it all.
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
    Aug 2005
    1
    Hi
    TNC 530 and C40U is the best.
    Good luck
    Sep 2005
    10
    Smile Heidenhain post
    I fished this post off the internet quite a while ago. It's the best one I've used for the 426/430 control in conversational. I also was an ISO code user. Believe me over time you'll see the conversational is much eaiser to use.
    Mar 2009
    3
    Hi
    My name is shajee i lookking for tnc 430 heidenhain controller post processor for cnc vertical milling machine. I need ISO code post processer for master cam version 9 or more or ...Please help me to send ...my mail is [email protected]
    Oct 2015
    1
    Re: Heidenhain post
    Once I download this file, where do I put it on my computer? I am using Mastercam X9 and it looks like I need an MMD file. Can someone help please?
    May 2013
    1
    Thank you for your software, I am looking for a long time.
    Feb 2011
    252
    hi,
    I have to SolidCAM.
    [email protected]
    May 2015
    Re: Heidenhain Tnc 360 Post Processor
    Hi... help help help : solidcam tnc 360 post prosodur... [email protected]
    Oct 2018
    1
    Hi
    my name Asep
    i m locking for TNC 426/430 Post for Mastercam X5
    any body can help me to get it
    thank you
    Jan 2020
    1
    I am using workcn , mastercam powermill and solidcam. Please send me post prosedur. [email protected]
    Jul 2014
    39
    Re: Heidenhain Tnc 430 Post Processor
    HI
    I NEED HEIDENHAIN POST TNC 426 5 AXIS MASTERCAM
    PLEASE....
Page 1 of 2 12
  1. HEIDENHAIN POST PROCESSOR
    By dmpdaz in forum Alphacam
    Last Post: 04-08-2019, 03:26 PM
  2. Post Processor for Heidenhain TNC 370
    By DoyleWright in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-11-2014, 08:00 PM
  3. Post Processor for heidenhain TNC 150
    By Sheepspeed in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-13-2009, 10:20 PM
