Hi everybody.
I bought this machine last year and the upgrades are as
follows. New mother board kit from EMI and new x & y drives boards also from EMI. Also I had my x servo motor rebuilt. If you think all that was expensive it was! All this hardware was installed by a Bridgeport factory Tech from the DB2 repair group here in Michigan. From the
begining I was having voltage issues from my phase converter so I had that rebuilt and now thats perfect. Now I got the machine up and running except for one thing. When I jog the x axis I get a drive fault just about every time I jog it. I did change the rapid default feed rate from 200 to 100 and that seemed to help. I also tried running a dry run sample program and it ran for about 15 minutes until I get a drive fault. Its only the x axis when I jog it though and usually only when I do a rapid jog.
Any comments would be helpful.
