586,619 active members*
2,398 visitors online*
Results 1 to 7 of 7
    Feb 2008
    19
    M01 Help needed
    Is there a parameter that allows the machine to restart the spindle etc. after a M01, as the machine I am currently using does not, but another one does.
    Jun 2008
    1511
    What kind of control are you using??
    I have not come across any parameter that will enable this. I have come across the same problem on 2 Fanuc 15 controls 1 works 1 does not. I just have a M3 command in after the M1's. I think that this is all determinded by the MTB. I could be wrong.
    Stevo
    Feb 2008
    19
    Stevo thanks for the prompt reply already doing it just wondered when the other machines dont require it, got another problem with tool change, on another forum, thanks again
    Feb 2008
    19
    Fanuc 18 model B
    Jun 2008
    1511
    Is that regarding the 18m on tool change recovery?
    Stevo
    Feb 2008
    19
    Yes, during tool change when machine crashes tool recovery states move to tc Zero but actually moves to Machune zero difficult to remove tools from arm during this, service engineer doesnt know why it moves to machine zero instead of tc zero????
    Jul 2003
    263
    Quote Originally Posted by tturnbull50 View Post
    it is not a parameter but a keeprelay that allows the fanuc control to do that but then again it is up to the machine builder which keeprelay they decide to use
    If you can ENVISION it I can make it
  1. cnc diy help needed!
    By ZenOrbit in forum Community Club House
    Last Post: 09-10-2008, 07:51 AM
  2. help needed
    By Korte in forum Want To Buy...Need help!
    Last Post: 03-07-2008, 11:27 PM
  3. New to this help needed!
    By Coolcuttings in forum Hobby Discussion
    Last Post: 12-16-2006, 05:53 AM
  4. help needed
    By tomcook in forum G-Code Programing
    Last Post: 07-06-2006, 09:42 AM
  5. New VMC needed
    By Scott_bob in forum Uncategorised MetalWorking Machines
    Last Post: 08-22-2004, 06:19 PM
