hi
PWM Chopper-Type bipolar
Stepping Motor Driver IC
Schematic and pcb TB6560A whit protel dxp.
Features
• Single-chip bipolar sinusoidal micro-step stepping motor
driver
• Uses high withstand voltage BiCD process:
Ron (upper lower) = 0.6 Ω (typ.)
• Forward and reverse rotation control available
• Selectable phase drive (2, 1-2, W1-2, and 2W1-2)
• High output withstand voltage: VCEO = 40 V
• High output current: IOUT = HQ: 3.5 A (peak)
FG: 2.5 A (peak)
• Packages: HZIP25-P-1.27/HQFP64-P-1010-0.50
• Built-in input pull-down resistor: 100 kΩ (typ.)
• Output monitor pin equipped: MO current (IMO (max) = 1 mA)
• Equipped with reset and enable pins
• Built-in overheat protection circuit
