586,766 active members*
8,839 visitors online*
    Jul 2008
    13
    Postprocessor for Camworks and Mach3
    I've just received a Deepgroove Taig CNC mill and was wondering if I will need a postprocessor file. I'm using Camworks and Mach3. I'm new to CNC so I hope someone can help.
    Joe
    Jan 2011
    Hi, I'm also interested in finding a postprocessor CAMWorks to Mach3. I've read that is possible create a post-processor using the program UPG,but I do not know, please help. A greeting and thanks
    Nov 2004
    65
    from camworks , select Fanuc postprocessor , works fine here with mach3
    Mar 2008
    25
    I can not run the follow g code in Mach3. What changes I have to do?
    O0001
    (Main Spindle)
    (Must Customize Main Spindle Per Machine)
    N1 G50 S3000
    N2 T0100 M42
    N3 G00 G97 S1001 M03
    N4 G00 Z2.743 T0101 M08
    N5 X75.962
    N6 G71 P7 Q9 U.254 W.254 D2540 F.007
    N7 X60.096
    N8 G01 Z-.193 F.007
    N9 G02 X70.089 Z-16.926 R35.471
    N10 G97 S3281 M09
    N11 G40 G00 X508. T0100
    N12 G00 Z254.
    (Main Spindle)
    N13 M01
    N14 G50 S3000
    N15 T0200 M42
    N16 G00 G97 S899 M03
    N17 G00 X65.176 T0202 M08
    N18 Z2.347
    N19 X60.096 Z-.193
    N20 G02 X70.089 Z-16.926 R35.471
    N21 G00 Z-19.866
    N22 G02 X60.096 Z-36.6 R35.471
    N23 G00 X508.
    N24 G97 S3281 M09
    N25 Z254. T0200
    N26 M30
    I know that the problem is Line 6. G code was generated in CamWorks.
    Regards
    M Zambrano
    Oct 2005
    7
    Re: Postprocessor for Camworks and Mach3
    hello,
    like you i'm looking and not finding .. did you ever find an answer???????
    i'm using a camworks OEM software package, and running it through a 3rd party mach3 package to a home built cnc machine. would really like to find a postprocessor
    larry from alaska
    Mar 2008
    25
    Hi Larry
    I did not find. I started working with BobCAD lathe version. This software has a processor for Mach3 and now everything is fine.
    Mike
  1. Postprocessor Camworks to Mach 3
    By mazaracing in forum CamWorks
    Last Post: 02-11-2011, 10:29 PM
  2. Camworks to Mach3
    By mazaracing in forum Mach Mill
    Last Post: 01-23-2011, 11:36 PM
  3. CAMWORKS to MACH3
    By mazaracing in forum Post Processor Files
    Last Post: 01-23-2011, 11:27 PM
  4. EMC2 postprocessor for Camworks
    By spacewalker in forum LinuxCNC (formerly EMC2)
    Last Post: 10-28-2006, 03:38 PM
  5. search postprocessor EMC2 for CAMworks / Solidcam
    By spacewalker in forum G-Code Programing
    Last Post: 10-01-2006, 11:33 PM
