587,040 active members*
2,861 visitors online*
IndustryArena Forum > CAM Software > Mastercam > cutting a slot with a t-slot cutter
Results 1 to 12 of 12
    Dec 2005
    436
    I want to cut a slot with a T-slot cutter.
    I'm using a 2d contour toolpath
    I can't get MC X2 to start cutting at the top of the slot. It always starts below the top of the slot by a distance equal to the depth of cuts.
    How do I force MCX2 to start cutting at the depth I want.
    Sep 2008
    18
    Are you cutting a t slot or just using a t slot cutter?
    Dec 2005
    436
    Quote Originally Posted by AbsoluteZero View Post
    Cutting a slot
    The cutter is about .100" high, my slot needs to be about .15".
    So I have to do a pass at a given Z, then move dow .05" to a final depth.
    I get the final depth, but the start Z off by my depth of cut.
    Mar 2005
    461
    If you wanted to do it in 2 passes it may be simpler to make 2 operations out of it.
    Otherwise, you could change the height of the first pass by adjusting the "top of stock" value. This was not my first choice only because I *think* it could be slightly unpredictable where the first pass lands with depth cuts activated but I am away from my hasp right now and can't test this theory...
    Either way, if you play around with it I am sure you can get it to do what you want.
    Sep 2008
    18
    Two operations would solve all your problems. I dont see why it wont work for you I just ran that through with false numbers and with a final z set I told it depth cuts value of .05 and it generated a two pass slot. Also you could try to lie to the software and tell it its a normal end mill it wont look right on verify but the fact that its compensating for a slot cutter might be messing it up. Any case fastest way tell it a contour pass with a final z and then copy the contour and change final z by .05.
    Dec 2005
    436
    Quote Originally Posted by cncuser1 View Post
    Thanks Guys it looks like it will work, a little bass akwards, but it seems to work, I'll try it on some metal tomorrow
    Apr 2003
    3578
    I know it can be done properly even with a custom keycutter like this one used in thread re leafs for valve body's. here is one I just did on a project I just finished programming.
    http://www.mastercam-cadcam.com/keycutter.wmv
    Cadcam
    Dec 2005
    436
    Quote Originally Posted by cadcam View Post
    Thanks Cadcam, as far as I can tell I did what your video shows ( no sound?) but like I said the first cut is below where I want by an amout equal to the depth of cut.
    I think all the countouur 2D cuts start at a depth below top of stock equal to cut depths? No?
    I am using MCX2, maybe they have different algorithm for X3.
    I think I solved the problem by doing a new, separate toolpath at each depth I want.
    Apr 2003
    3578
    CNC user want to share your file so I can see what you are doing? you can email it to me if you want.
    Cadcam
    Sep 2007
    126
    Question for cadcam
    Good video by the way. Please see if I am understanding this correctly. Top of part is 2.4855, bottom is 2.4255, a differance of .060, plus a stepdown of .025 for a total width of groove, or relief, is .085. Is this correct ? Thank's . Harold C
    But after watching video again, the differance of .060 is total width of relief & cutter is .035 with .025 stepdown ???
    Sep 2007
    126
    Thank's for the tip !
    I finally figured this one out. Made my own model & custom t-slot cutter & played with it for a short while, & got it. Work's like a charm. We don't do many internal / external grooves , but we do them from time to time. Very helpful. Thank's. Harold C.
    Apr 2003
    3578
    I guess now I need to make a short video showing a keycutter doing and undercut surface path.
    Cadcam
  1. T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding / Toolgrinding Machines
    Last Post: 09-13-2010, 06:25 PM
  2. X2 Slot mill and cutter comp. don't work?
    By foxsquirrel in forum Mastercam
    Last Post: 04-20-2008, 10:15 PM
  3. How do I use a dove tool cutter & slot cutter
    By bobby1 in forum BobCad-Cam
    Last Post: 04-16-2008, 02:06 AM
  4. Slot Cutter Holder Arbor type, cant find??
    By mgb1974 in forum MetalWork Discussion
    Last Post: 03-10-2008, 01:36 PM
  5. Replies: 7
    Last Post: 04-12-2007, 03:00 AM
