586,835 active members*
2,731 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > easy tacho or encoder: cny70 reflective optical sensor
Results 1 to 1 of 1
    Feb 2004
    77
    Today I tried an electronic easy made circuit with "CNY70 Reflective Optical Sensor with Transistor Output" The circuit contains only two resistor and CNY70.
    You can download CNY70 datasheet from http://personal.telefonica.terra.es/...eets/cny70.pdf address and easily try attached circuit.
    I did not use 74HCTxx only two resistor and CNY70 gives logic signals.
    All questions and suggestions are wellcome
    Gunol Camlibel
    [email protected]
    http://www.rc-tuning.com
  1. Optical sensor...
    By aghobby in forum DIY CNC Router Table Machines
    Last Post: 09-08-2004, 05:17 PM
  2. Optical Encoder Differential Line Driver
    By azsigns in forum CNC Machine Related Electronics
    Last Post: 03-04-2004, 10:41 AM
