586,385 active members*
3,345 visitors online*
    May 2008
    26
    MULTI-MACHINE PROGRAMMING
    Has anyone setup SolidCam so that the programs can be easily modified to run on different machine tools. Our company uses several machine tools with slighty different setups; but a programm could be used on any of them depending of machine availablity.
    Hope that makes some sense
    Oct 2007
    499
    Quote Originally Posted by almo0797 View Post
    You do this using the post processor files, the *.MAC file which is where you set the different settings for the machine and the *.GPP file where you make the changes to the code (the GPP file is referenced by the MAC file). For example, say you had a machine that required the G83 call to have a dwell variable called P instead of Q. Simplely make a copy of your existing post files and rename them. Edit the MAC file to call the renamed GPP file and then find the bit in the GPP file that deals with G83 and edit accordingly.
    Then when you want to post an existing program to your different machine, just edit the CAM settings in the part file.
    May 2008
    26
    Thanks Bob
    Can this also deal with changes in tool parameters. For example most of our machines run identical tool cribs but with different power ans speed capacities.I want to vary the speeds and feeds for each tool to suit each machine without editing every tool individually.
    Oct 2007
    499
    Thanks Bob
    Would the best way of dealing with that be using a local variable in the program for speeds & feeds (presuming that your machines are running a flavour of Fanuc or similar)?
    You can also set your machine post (MAC) to reference a particular tool library and when you create copies of a tool library SolidCAM will offer a very crude method of altering speeds & feeds. I dream of the day when I can make a post reference a look-up table for machine dependant speeds & feeds.
    May 2008
    26
    This would be a great enhancement. Hope SolidCam are taking note.
    daveallen Guest
    Re: MULTI-MACHINE PROGRAMMING
    For a free trial of The Machinist Black Book email DaVicki-llc@outlook,com and put trial in the subject.
    Speed and Feed calculator for over 3000 materials and handy references for the machinist and programmer.
  1. Secios Multi L Programming tool files
    By TMSPD in forum Uncategorised MetalWorking Machines
    Last Post: 01-22-2013, 02:33 PM
  2. Multi-axis aggregate programming
    By CWMDB in forum Uncategorised CAM Discussion
    Last Post: 07-28-2012, 05:25 PM
  3. multi-head router CAM programming
    By Ziggy33 in forum Uncategorised CAM Discussion
    Last Post: 03-06-2012, 06:34 PM
  4. Multi function machine
    By StevecGarry in forum DIY CNC Router Table Machines
    Last Post: 09-11-2010, 12:59 AM
  5. Replies: 0
    Last Post: 12-25-2008, 08:18 PM
