586,471 active members*
3,970 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Bmc ball screw support bearings
Results 1 to 8 of 8
    Jul 2003
    71
    Where can I find the special tool to remove and torque the y axis ball screw support bearing nut on my 1990 BMC 20? Anyone know what the proper torque for that would be? Should I pack the new bearings with any special grease?
    Jun 2008
    1104
    use mm25bs62 fafnir. they are preloaded when tight. grease rocol sapphire2
    Jun 2008
    1104
    aha. unless it has linear guides. in that case, fafnir mm35bs72
    Jul 2003
    71
    Getting the bearings(mm25bs62) is no problem. I need the proper tightening torque for the nut.
    Jul 2003
    71
    I've replaced the bearings in the Y axis twice in the last seven years. I think the machine hits during calibration and that might be damaging the bearings over time. I'm going to move the limit switch stop about .05-.100 to see if that helps prevent it from slamming the back.
    May 2005
    117
    What bloke was explaining is that the bearings have the preload ground in already. You tighten them up tight (as you can) and they will have the correct preload when the centres are tight together.
    Jul 2003
    71
    Quote Originally Posted by gthlm View Post
    So there is no real torque spec on the nut?
    Jul 2003
    71
    Turns out the bearings were not the backlash problem. Tightening the drive/timing belt cured the problem. I did obtain a Hurco service bulletin for the BMC20 bearings and found out that Hurco recommends that they be mounted DB instead of DF as is the common practice. The correct torque is 40-45 ft/lbs
  1. VMC 2216 Thrust Bearings and/or Ball Screw
    By Billet Sean in forum Fadal
    Last Post: 08-30-2008, 02:25 PM
  2. Attaching bearings to a ball screw
    By ranchak in forum Linear and Rotary Motion
    Last Post: 09-22-2007, 06:01 AM
  3. installing ball screw bearings
    By dgalaxy in forum Bridgeport / Hardinge Mills
    Last Post: 09-01-2006, 03:06 PM
  4. Loose ball screw support
    By cbass in forum Uncategorised MetalWorking Machines
    Last Post: 08-07-2006, 02:01 AM
  5. Ball screw without bearings?
    By Halfnutz in forum MetalWork Discussion
    Last Post: 06-13-2005, 09:10 PM
