586,275 active members*
3,362 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > converting imported part drawing to mold drawing
Results 1 to 7 of 7
    May 2006
    196
    First off I am still using ver 21. How do you guys quickly convert the part (solid) your customer sends you to a mold drawing. I can stumble around using boolean functions, but I was wondering how you guys would go about it.
    Jul 2008
    38
    In a different program that I use, you can automatically generate 2D drawings from solids. Not sure if BC has that feature, but I can see where it sure saves a lot of time.
    Eric
    May 2006
    196
    Quote Originally Posted by etzz View Post
    Eric
    Which program would that be?
    Jul 2008
    38
    Rhinoceros (www.rhino3d.com). Not really a competitor to Bobcad anyway. I would think its a common function in CAD software these days. Bobcad is more of a CAM program, but it may have the feature. Hopefully some Bobcad users will chime in (ive tried the demo for 21 and 22).
    Eric
    Dec 2006
    406
    How you break a mold up depends on what your making. You may need only 2 pieces for your mold. You also may need 10. How you break it up depends on what your molding.
    judleroy
    May 2006
    196
    It will be a 4 plate transfer rubber mold.
    I was wondering after you would receive the solid what functions do you use in Bobcad to create your mold drawing. Would you use the boolean function? Are there any other ways to reverse the surfaces? So say that I want the ID of your part to now be the OD on your insert.
    May 2006
    196
    Eric
    I have downloaded the eval. version of Rhino, but haven't had too much time to play with it.
  1. Converting drawing for Burny CNC Plasma Cutter
    By Turbo1zz in forum Waterjet General Topics
    Last Post: 07-06-2017, 07:10 PM
  2. Cirles embeded behind my drawing when imported into Mach3
    By Mick40 in forum Mach Plasma / Laser
    Last Post: 02-16-2008, 10:29 PM
  3. Drawing on my CNC
    By monte55 in forum DIY CNC Router Table Machines
    Last Post: 01-18-2008, 08:10 PM
  4. Part->Block->Drawing-> Dimension
    By cncuser1 in forum Solidworks
    Last Post: 11-26-2007, 09:22 PM
  5. Is making a part as easy as drawing it in 3d?
    By randyf1965 in forum Commercial CNC Wood Routers
    Last Post: 04-05-2006, 01:23 PM
