586,391 active members*
3,016 visitors online*
    Dec 2006
    13
    slant bed lathe?
    I'm a longtime reader of the forum but have rarely posted,
    I'm designing a CNC gang tooled lathe, I'm using a XY table from a Taig mill for the cross slide, and 400 once/inches steppers for control. I'm using a Hardinge high speed head stock for it and 2x6 1/4" steel for the frame. The problem I've run in to is that my headstock is designed for the motor to be mounted underneath. The problem I face is that it if I place the motor under the lathe as is i'll end up with the lathe very tall, I was thinking about making the whole lathe a slant bed lathe. Basically mounting it at a 45 degree or so angle. Then I could mount the motor under the headstock and not have the lathe be too tall.
    Here is a picture of my set-up so far.
    http://s133.photobucket.com/albums/q...t=DSCF1244.jpg
    the advantages I see are:
    the coolent and chips will be easier to collect
    the lathe wont' take up as much room on my bench.
    does anyone else have any opinion?
    -Chris
    May 2006
    573
    It would work. Just remember that your x-axis has to fight gravity when you slant it. Also the new height is determined buy the "height" of the x-axis (in a 45deg angle). It could end up higher than just putting the motor underneat. Have you considered putting the motor underneat the bench?
  1. Slant bed CNC lathe from scratch
    By Guldberg in forum Vertical Mill, Lathe Project Log
    Last Post: 06-18-2021, 05:25 PM
  2. Does someone know about Hardinge Super Slant Lathe?
    By dadv2 in forum MetalWork Discussion
    Last Post: 01-29-2009, 07:15 PM
  3. MAZAK Quick Slant 30N 4 Axis CNC Lathe
    By ISHY in forum Uncategorised MetalWorking Machines
    Last Post: 08-24-2008, 09:05 PM
  4. Slant-bed lathe question
    By zephyr9900 in forum Mechanical Calculations/Engineering Design
    Last Post: 09-08-2007, 01:57 AM
  5. What's the advantage of a slant bed lathe?
    By Splint in forum Uncategorised MetalWorking Machines
    Last Post: 07-25-2007, 03:59 AM
