586,156 active members*
3,618 visitors online*
Results 1 to 10 of 10
    Sep 2006
    1738
    EMC Backlash compensation
    I own a Taig Mill, I would like too know where I can plug the backlash into EMC for compensation?
    Anyone?
    -Jason
    May 2005
    1662
    The backlash settings are found in the ini file under each individual axis, AXIS_0, AXIS_1, etc.
    The backlash lines may not appear in a stepconf generated ini file. Should be okay to edit them in afaik. Look at the generic stepper_inch.ini file for an example of where to add these lines.
    Sep 2006
    1738
    Ok, thanks cycle. If I have any problems, I will be sure too ask
    -Jason
    Feb 2007
    514
    Here is a link to the manual page
    http://www.linuxcnc.org/docview/html...XIS%5D-Section
    John
    Sep 2006
    1738
    Quote Originally Posted by cyclestart View Post
    This is way overdue but, if the Backlash does not appear in the ini file. Can I simply put it in manually?
    Ex:
    MAX_VELOCITY = 1.2
    MAX_ACCELERATION
    BACKLASH
    = 0.003
    Should I then be ok?
    -Jason
    Mar 2006
    474
    Yes, that's exactly how to do it. I had to add my own backlash settings a few weeks ago when I switched to EMC.
    Sep 2006
    1738
    How is working out for you?
    -Jason
    Mar 2006
    474
    The backlash settings, or EMC in general? The backlash is fine, EMC's compensation works well. I had an early problem with it, but I'd caused it myself by messing with the setup and setting the axis' acceleration slower than allowed.
    EMC2 works fine as well, I'm a lot happier with it than I was with the windows-based program I was using previously. It's been well worth the format and installation of Linux, in my opinion.
    Feb 2007
    514
    Just a bit of info on using Backlash here
    http://www.linuxcnc.org/docs/devel/h...nfig.html#sub:[AXIS]-section
    If you get following errors read the backlash section of the above link for the 2.3 docs
    John
    Sep 2006
    1738
    Wow the backlash compensation worked so easily and nicely! Very impressed and very happy that I have finally input the code into the file. Very happy.
    -Jason
  1. Backlash Compensation
    By solek in forum Benchtop Machines
    Last Post: 03-05-2008, 08:22 AM
  2. Backlash Compensation
    By cnccustom in forum Mach Mill
    Last Post: 11-22-2007, 02:33 AM
  3. Backlash compensation at GE MC2000
    By bobecm in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-07-2007, 01:30 PM
  4. Backlash Compensation
    By utengineer04 in forum MetalWork Discussion
    Last Post: 04-26-2005, 05:42 PM
