586,565 active members*
3,577 visitors online*
Page 5 of 6 3456
Results 81 to 100 of 113
  1. #81
    Oct 2010
    93
    Thanks Bill!
    I'm doing some other PCBs at the moment and might add this one on the corner of a sheet.... I'll have a go at adding the PSU components in the bottom left corner.
    Cheers,
    Joe
    Joe in Aus
  2. #82
    Aug 2008
    573
    If you succeed, be sure to post the results here so other can benefit
    Bill
    Bill
  3. #83
    Oct 2010
    93
    OK. Haven't done anything 'electronic' over the weekend after all, but had a go at the 'mechanicals' for my set-up.
    A close look at my Fujitsu Pen computers and my milling machine discovered a relatively easy way to mount it: a simple steel angle frame and a quickly bent top clamp would mount the PC securely and there was a 5/8" thread in the top of the mill (perhaps for a difting eye or hook?) which lent itself to be used as a mounting point - out of the way of coolant spashes and accidentally flying tools or work pieces
    Here are a couple of photos. Nothing is cleaned up or painted yet - just testing function.... :idea: No connections or anything yet, and only the X-axis scale mounted so far at the very bottom of Photo 3 - no cover made or fitted yet). The images show the 'Demo Mode' of Bill's Vernier Display.
    Cheers,
    Joe
    Joe in Aus
  4. #84
    Oct 2010
    93
    Finally made another step forward: revised the PCB layout for this DRO controller, removing the redundant components and adding the supply regulator parts to the board.
    I've now etched and drilled a prototype, ready to add components (not all here yet). I even managed to get myself a chip programmer and with Bill Todd's help via e-mail got the PIC progammed.
    Next step is to complete the board and test it and mount the remaining two scales (hacked vernier calipers) on the milling machine.
    THen wire everything up and report back
    Attached Thumbnails Attached Thumbnails pcb.jpg   pcbTRACKS.jpg   drilling_PCB.jpg
    Joe in Aus
  5. #85
    Oct 2010
    93
    Well, I have finally completed the assembly of the DRO PCB and found a small mistake: R6 is shown connected to the wrong hole in the previous post. It's lower leg should be connected to the spare hole between C1 and D3 on the +3.5V bus. I'll post an updated image once I've established everything is working.
    Still having some trouble getting my scales to behave. Will post once this is sorted.
    Boy are the connectors on the scales tiny! Much too small for my big fingers, tools and soldering iron! Working under a strong magnifying glass is the only way for these old eyes to even get close....
    Cheers,
    Joe
    Joe in Aus
  6. #86
    Jul 2009
    20
    Well it's been a long time since I visited this thread... It looks as though a few more people have taken interest in this.
    I had to put my hobbies on hold for quite some time but am now back into the process full swing...
    I wanted to mention that Microchip has since come out with a very interesting little chip that would be fantastic for this as a replacement to the 12F765 being used. The chip is the 12F1822 and you can read about it here. It has an internal 32MHz oscillator as well as hardware USART.
    Anyhow I just wanted to mention it as it should make life a little simpler for anyone wanting to start from scratch on the project. I will be starting in on it again fairly soon using these chips along with a larger chip running the "interface" to a larger LCD for a stand-alone solution. Or I may use some of the usb/serial 7 segment displays I just finished.
  7. #87
    Aug 2008
    573
    Interesting that hardware SPI would make chaining a number of these together a whole lot easier .
    BTW Prompted by Joe (in Aus) I've updated the VB program and have added another vernier/scale type to the PIC code (this is an odd one I found, the scale displays fractions of an inch as well as decimal and uses a fixed rate BCD format protocol).
    The VB app is now scalable so will fit different window sizes. I've added linear speed (in inches per minute or mm/s) for each axis and it can display a Tacho/rev counter with the ability to set tool diameter thus giving tool cutting speed (requires a different PIC code and a opto sensor - see zip file)
    If any one is interested, I'll package it up into an installer exe. (see attached)
    Attached Files Attached Files
    Bill
  8. #88
    Oct 2010
    93
    Hi Bill.
    Thanks for the update.
    I still haven't got anywhere with my DRO - I can't get it to recognise the scales at all. I kind of gave up a couple of months ago in frustration.
    In the process of resoldering and replacing various resistors and transistors, I destroyed a couple of tracks as well.....
    I'll have to start from scratch and do new pcb design. I'll make the tracks a little fatter, the gaps a little wider and may use in-line scale connectors or in-line headers for the scale connectors. The staggered connectors - or rather the tracks running between them did mine in.... I would really not mind if the whole board is a bit bigger. I'd rather find a bigger enclosure than work under a microscope for the entire assembly
    PS: As you know, I also have a 24" long scale - I have since found a description of it's 21-bit code! I'll e-mail you the details.
    Joe in Aus
  9. #89
    Aug 2008
    573
    Quote Originally Posted by jhovel View Post
    Hi Bill.
    Please do
    Bill
  10. #90
    May 2006
    41
    As to using the PICs with quadrature encoder, I'm sure the little 8 pinners I've used lack the necessary hardware (you'd need a couple of fast counters to ensure no pulses were lost). The ones to use would be the dsPIC devices like the 30F4012 (?) which have the quadrature hardware inside.
    Has anybody mentioned the encoder interface chips from USDigital yet?
    ( US Digital | Products » Interfaces » ICs )
    I often have to do low-volume encoding based systems in microcontrollers, and I end up using these chips a fair amount, particularly the LFLS7366R standalone encoder counter to SPI chip.
    They're useful when you need one controller to monitor several channels, especially if some channels can have high count rates. You set 'em up and then just come back and poll them once in a while.
    I find they're much more cost-effective than the old Agilent chips.
    You can also buy all these chips direct from their original manufacturer, LSI, but USdigital stocks them and sells them in small quantities and they're quite hobbyist-friendly.
    Also, thought it's off the PIC subject, since some people are talking about PC based solutions, USDigital also offers an encoder... dongle, I guess, that allows fairly direct plumbing from a quadrature encoder to a USB port.
    ( US Digital | Products » QSB Quadrature to USB Adapter )
  11. #91
    Aug 2008
    573
    That's a very useful chip
    Bill
    Bill
  12. #92
    Jul 2011
    Smile
    Quote Originally Posted by BillTodd View Post
    I'm not actually reading encoders. I'm decoding the digital data outputs of those cheap Chinese digital calipers (see :examples here). To keep my circuit simple, I'm using the PICs onboard comparitor and reference to convert the low level (~1.5v) signal to one that the PIC can read.
    This circuit is of a single device reader powered by the serial port.
    The LEDs (D1,2,3) limit the voltage to about 1.2v when the PIC drives the scale's inputs.
    Hi Bill, Interesting Thread, But will you please repost the image..... I found a broken link here.
    Also if can you please refer any PC Interface for Magnetic Linear Scales.:withstupi
  13. #93
    Aug 2008
    573
    I'm not sure which image you mean? which message number?
    Bill
    Bill
  14. #94
    Jul 2011
    Red face
    Bill
    Hi Bill, i think i have overlooked your attached link before. i was just looking for your circuit.
    :idea:Also will you please suggest me any thing good for my Magnetic Scales. Can I read the same with your Circuit.:idea:
  15. #95
    Aug 2008
    573
    Quote Originally Posted by aadityadengle View Post
    :Also will you please suggest me any thing good for my Magnetic Scales. Can I read the same with your Circuit.:idea:[/COLOR][/B]
    Do the magnetic scales have a display (read-out) or do the magnetic scales will output a quadrature ttl level signal on two wires?
    Bill
  16. #96
    Jul 2011
    Yes!!!! Phase A & B with TTL I am using Magnetic Encoder ME6012 { Data sheet available @ ( http://www.google.co.in/url?sa=t&rct..._DNsH1LkQBYTZQ ) }
    Now can I use it with your circuit. I am new to the electronics
  17. #97
    Jul 2011
    tried to connect with Magnetic Encoder but no use:drowning:
    DATA == Cha A
    Clk == /A
  18. #98
    Aug 2008
    573
    No Sorry
    My PIC code works only with the 'chinese' LCD callipers (these output a binary code).
    Your scale needs a 'quadrature' counter - you may be able to find some other software to work with the scale (I believe the linux based EMC2 can do this)
    Bill
    Bill
  19. #99
    Jul 2011
    tried the circuit with verniers too
    but no data
  20. #100
    Aug 2008
    573
    but no data
    :bs:
    :bs: like that's going to get you an answer !
    Bill
Page 5 of 6 3456
  1. Is water based
    By cncadmin in forum Safety Zone
    Last Post: 10-19-2022, 05:10 PM
  2. Need help with CNC UK based
    By ciscoe in forum European Club House
    Last Post: 07-21-2008, 12:03 PM
  3. Pic based Oscilloscope
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:48 PM
  4. PC Based Controls
    By zimbricd in forum News Announcements
    Last Post: 12-12-2007, 09:38 PM
  5. dos based cnc software
    By flyingmike in forum Computers / Desktops / Networking
    Last Post: 11-25-2005, 08:29 PM
